在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3603|回复: 1
[求助] SDX中调用HLS编译问题?
发表于 2017-11-23 15:09:41 | 显示全部楼层 |阅读模式
SDX2017.02直接建sdx的示例工程Synthesizeable FIR Filter,然后直接编译,无法通过:
显示
Moving function cpp_FIR to Programmable Logic
ERROR: [IMPL 213-28] Failed to generate IP.
command 'ap_source' returned error code
    while executing
"source D:/SDPrj/hlstest/Debug/_sds/vhls/cpp_FIR_run.tcl"
    invoked from within
"hls::main D:/SDPrj/hlstest/Debug/_sds/vhls/cpp_FIR_run.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
INFO: [HLS 200-112] Total elapsed time: 52.436 seconds; peak allocated memory: 92.660 MB.
好像无法生成IP,而且其他的示例工程也一样
什么原因?
 楼主| 发表于 2017-11-24 09:57:30 | 显示全部楼层
没有人遇到同样的问题吗?
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-21 00:24 , Processed in 0.016447 second(s), 7 queries , Gzip On, Redis On.
