在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 992|回复: 0
[招聘] 北京数字设计项目经理(数字设计,验证等岗位都有)
发表于 2017-11-22 09:33:22 | 显示全部楼层 |阅读模式
有兴趣的可以发简历hamy@hibohr.com,或者加微信13512136297沟通
1 asic Design Project Leader /数字设计项目经理
工作职责:
[size=10.5000pt]1. Responsible for whole chip development and leading digital team to develop digital blocks according to product specifications;
[size=10.5000pt]2. Logic design & implementation by verilog on module level, and chip integration;
[size=10.5000pt]3. Design synthesis, CDC checking, timing analysis, DFT and ATPG;
[size=10.5000pt]4. Work closely with Analog and backend engineer for chip physical design and tape-out;
[size=10.5000pt]5. Work closely with application engineer for chip bring-up, debug and solve problem;
[size=10.5000pt]6. Good IC verification skills and solid logic and circuit design knowledge, good communication and problem solving skills;
[size=10.5000pt]7. Interest of IC project management. Good knowledge of Perl and shell programming would be an added advantage.
职位要求:
[size=10.5000pt]1. Bachelor, Master or above in Electronic, Communications, Microelectronics Engineering and Computer Science;
[size=10.5000pt]2. At least 8+ years of experience in digital design based on high-level languages (preferable Verilog), with knowledge of ASIC FE design flow, including coding, simulation, verification, synthesis, DFT and STA;
[size=10.5000pt]3. Familiar with EDA tools from Synopsis, Cadence or Mentor, like NC-Verilog, VCS, DC and Prime Time;
[size=10.5000pt]4. Familiar with video/image process algorithm would be an added advantage;
[size=10.5000pt]5. Experience of chip volume production;
[size=10.5000pt]6. Familiar with FPGA prototyping development;
[size=10.5000pt]7. Familiar with mixed signal or SoC design is better;
[size=10.5000pt]8. Good written and oral English communication skills.
职位  2  Sr. ASIC Design Engineer / 高级数字设计工程师
工作职责:
1.   Logic design & implementation by Verilog on module level, and block integration;
2.   Design synthesis, CDC checking, timing analysis, DFT and ATPG;
3.   Work closely with application engineer for chip bring-up, debug and solve problem;
4.   Good IC verification skills of logic and circuit design, good communication and problem solving skills;
5.   Experience with verification tools such as System Verilog, UVM or System C/Testbuilder, etc.
6.   Good knowledge of Perl and shell programming would be an added advantage.
职位要求:
    Computer Science;
2.   At least 5+ years of experience in digital design based on high-level languages (preferable
    Prime Time;
5.   Familiar with FPGA prototyping development;
6.   Familiar with mixed signal or SoC design is better;
7.   Good written and oral English communication skills.
职位 3  ASIC Design Engineer / 数字设计工程师
工作职责:
Design and implement digital circuits in advanced CMOS technology;
Develop and improve new and existing circuit solutions;
Present and receive technical feedback at reviews;
Document RTL design and communicate with other designer;
Understand system level architectural design;
Work with team members to resolve technical issues;
职位要求:
Bachelor, Master or above in Electronic, Communications, Microelectronics Engineering, Computer Science or relative major;
At least 3+ years of experience in digital design based on high-level languages (preferable Verilog), with knowledge of ASIC FE design flow, including coding, simulation, verification, synthesis, DFT and STA;
Familiar with front end EDA tools;
职位 4
Sr. Verification Engineer/高级数字验证工程师
工作职责:
1.   Create, developing and maintain verification testbench environment;
2.   Developing test case and regression plans;
3.   Work close with designers and understanding the expected functionality of designs;
4.   Running RTL and gate-level simulations/regression;
5.   Code/functional coverage development, analysis and closure;
6.   Release the documents during the verification flow. Such as verification plan, usage of the verification environment, simulation result of test cases, verification coverage report, etc.
职位要求:
1.   Minimum of 5 years design/verification experience (test plan, test bench, assertions,‎ debugging designs, code coverage etc.);
2.   Knowledge in ASIC/FPGA design process and verification tools/env (UVM/OVM…);
3.   Familiar with design and verification languages (Verilog, System Verilog, SVA etc.);
4.   Familiar with C/C++, Perl/Python and other script/automation skills (tcl, makefile etc);
5.   Additional qualifications include: Good IC verification skills and basic knowledge of logic or circuit design, good communication and problem solving skills, English and other foreign languages;
职位 5  Verification Engineer/数字验证工程师
工作职责:
1.   Understanding the expected functionality of designs;
2.   Designing and developing verification environment;
3.   Running RTL and gate-level simulations/regression;
4.   Code/functional coverage development, analysis and closure;
5.   Release the documents during the verification flow. Such as verification plan, simulation result of test cases, verification coverage report, etc.
职位要求:
1.   Minimum of 3 years design/verification experience (test plan, test bench, assertions,‎ debugging designs, code coverage etc.);
2.   Familiar with design and verification languages (Verilog, System Verilog, SVA etc.);
3.   Scripting and automation skills (tcl, perl, makefile etc) a plus;
4.   Additional qualifications include: Good IC verification skills and basic knowledge of logic or circuit design, good communication and problem solving skills, English and other foreign languages;
职位 6  Leader of Algorithm Development (image / video algorithm)/视频图像算法开发
工作职责:
Manages team of Algorithm Engineers and has strong leadership and motivational skills;
The candidate will be strong in modeling, simulation, evaluation, validation, and hardware implementation of algorithms for display;
Responsible for image / video processing algorithms of the research, design and implementation, as well as the algorithm improvement, optimization for display;
To make Algorithm design requirements, and design Algorithm architecture document, Algorithm primary design documents, Algorithm details design documents;
To co-work and support Software / Hardware / Application engineer to finish system developing.
职位要求:
Master or Doctor of CS / EE / Math or Related Majors with above eight years’ algorithm related experience;
Solid knowledge and experience on C / C++ / matlab and debugging skills;
Strong background in at least one of the following areas:
Image processing, Video pre- or post- processing;
Familiarity with panels (such as LCD, OLED) image processing would be an added advantage;
Knowledge of computer architecture, skill in problem solving and identifying performance bottleneck for algorithm optimization;
Be familiar with ASIC development flow and verification requirement;
Great technical passion, be able to learn new technologies quickly.
职位  7
Chip Architect/Staff ASIC Design Engineer /芯片架构师/资深数字设计工程师
工作职责:
[size=10.5000pt]1. Responsible for architecture definition according to product specifications;
[size=10.5000pt]2. Logic design & implementation by Verilog on module level, and chip integration;
[size=10.5000pt]3. Design synthesis, timing analysis, DFT and ATPG;
[size=10.5000pt]4. Work closely with backend engineer for chip physical design and tape-out;
[size=10.5000pt]7. Experience with professional verification tools such as System Verilog, VMM/OVM/UVM or System C/Testbuilder, etc. Good knowledge of Perl and shell programming would be an added advantage.
职位要求:
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 07:29 , Processed in 0.020878 second(s), 7 queries , Gzip On, Redis On.
