Offline Andrew Beckettover 4 years ago
I believe this function comes from the "gdbm" shared library - running "ldd" on the LVSCHM executable suggests to me that it's from there:
linux-gate.so.1 => (0xf7782000)
libgfortran.so.3 => /usr/lib/libgfortran.so.3 (0xf76ab000)
libm.so.6 => /lib/libm.so.6 (0x00522000)
libnsl.so.1 => /lib/libnsl.so.1 (0x0067a000)
libdl.so.2 => /lib/libdl.so.2 (0x0051b000)
libgdbm.so.2 => /usr/lib/libgdbm.so.2 (0xf76a3000)
libtermcap.so.2 => /lib/libtermcap.so.2 (0xf769f000)
libelf.so.1 => /usr/lib/libelf.so.1 (0xf7687000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x0056b000)
libc.so.6 => /lib/libc.so.6 (0x00389000)
/lib/ld-linux.so.2 (0x00367000)
My guess is that your OS has an outdated or incorrect version of libgdbm.so.2 (I've seen one report saying that this doesn't work on SuSE, but I've got nothing to back that up). I see from your hostname that you are probably using Ubuntu, which is an unsupported operating system - so maybe that's the root cause?
Regards,
Andrew.
