在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1938|回复: 3
[解决] how do we get cm3_dsm_cfg.v ?
发表于 2017-10-25 20:08:10 | 显示全部楼层 |阅读模式
Hi.
I have some problem arm designkit need some extra file.If I want to use ARM_DSM define, then I need cm3_dsm_cfg.v
Does anyone have that relative files ?
  // Logic required for DSM generation
`ifdef ARM_DSM
`include "cm3_dsm_cfg.v"
`endif
发表于 2017-10-26 14:20:53 | 显示全部楼层
需要专门买的吧,我的理解是DSM是初粒度的仿真,不是实际RTL的行为,仿真RTL就好了。
 楼主| 发表于 2017-10-26 15:28:18 | 显示全部楼层
Can you check R15 (PC) work as well in hello example ?In my case, I can't find any update the PC value in the simulation.
Can you help me please ?
 楼主| 发表于 2017-10-26 15:30:00 | 显示全部楼层
답글 2 #을 y23angchen
    이것은 안녕하세요 예 simualtion. 당신은 시뮬레이션에서 작동하지 않습니다 R15에서 볼 수있는이. IS
   어떻게 우리가 이것을 undersatnd 수 있습니까?
   I want to see the working PC (R15)
hello
hello
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 19:06 , Processed in 0.019935 second(s), 7 queries , Gzip On, Redis On.
