各位eetop版友大家好~
我照着论坛的说明步骤安装 ic5141usr6 ~
在terminal看到下列讯息
Generating detailedinstallation data...
Determiningavailable disk space
sort: 开启时发生错误: +2: 没有此一档案或目录
Determiningrequired disk space
Disk checkssuccessful
我不管接下操作...看到下面讯息,我按下Enter键
The following mediais required:
IC5141 lnx86 P/N356-70352-0501 CDROM # 1
IC5141 lnx86 P/N356-70352-0502 CDROM # 2
IC5141 lnx86 P/N356-70352-0503 CDROM # 3
IC5141 lnx86 ISR200811110850 CDROM # 1
IC5141 lnx86 ISR200811110850 CDROM # 2
IC5141 lnx86 ISR200811110850 CDROM # 3
IC5141 lnx86 ISR200811110850 CDROM # 4
Press [Return] toproceed, q to quit :
Checking for IC5141lnx86 ISR 200811110850 CDROM # 1 .........
Extracting controlprograms .........
Updating packageinstallation information..................................................................................................
Checking datafiles...
Executing controlprograms (pre-load) ...
sort: 开启时发生错误: +3: 没有此一档案或目录
expr: 格式错误
SL-8: Noinformation available on :.
Call the CadenceCustomer Response Center (CRC) at 1-800-Cadenc2
(1-800-223-3622) toget the right /home/EDA/cadence/ic5141usr6/install/tmp/mediaMap.lnx86 file.
后来到这一步,就不知怎么操作了,接下一直和说明的不一样...
有人知道可以帮我吗?谢谢~ |
