doing P&R in ICCbut got the following error messages for prelude, clock tree compile failed
port sd_CKn is a output to the block
Error: Port 'sd_CKn' cannot inherit its location from the pin 'sdram_CKn_iopad/outputbuffer/Z', because the cell 'sdram_CKn_iopad/outputbuffer' is neither a pad-cell nor a macro-cell. Please check the library. (PSYN-117)
Error: Following Ports have no location. (PSYN-007)
Error: Command 'create_placement' had an error while executing. Discontinuing. (PSYN-003
it was a block level P&R, not the whole chip with I/O 's
I had 74 pin/ports at the level, but only sd_CKn pin got the complain
the command place_opt did run though.
please help |
