返回列表 发帖
[求助] set_wire_load_mode and set_wire_load_model not supported
I just got these messages:Warning: Constraint 'set_wire_load_mode' is not supported by icc_shell. (SDC-3)
Warning: Constraint 'set_wire_load_model' is not supported by icc_shell. (SDC-3)
both mode and model not supported, what happened. The SDC file is generated by Design Compiler.
Please help, do we have some commands to replace them?
回复 1# xiaoyisimonguo
wire load model只是综合工具用来估计线延时用的,ICC是不需要的,去掉即可
TOP
返回列表
站长推荐 关闭
瑞狗迎春--eetop摄影板块第五届春节&元宵节摄影大赛,现金大奖等你拿!!
查看
