在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2956|回复: 2
[求助] gds转化后的警告信息
发表于 2017-7-25 15:51:53 | 显示全部楼层 |阅读模式
1.WARNING (XSTRM-35): The objects in the layer-purpose pair 'MET2:pin' are ignored. This is because the layer-purpose pair used in the design is not specified in the layer map file. Specify the layer-purpose pair in the layer map file and try again.
2.WARNING (XSTRM-35): The objects in the layer-purpose pair 'MET1:pin' are ignored. This is because the layer-purpose pair used in the design is not specified in the layer map file. Specify the layer-purpose pair in the layer map file and try again.
3.WARNING (XSTRM-35): The objects in the layer-purpose pair 'MET4:pin' are ignored. This is because the layer-purpose pair used in the design is not specified in the layer map file. Specify the layer-purpose pair in the layer map file and try again.
4.WARNING (XSTRM-35): The objects in the layer-purpose pair 'MET3:pin' are ignored. This is because the layer-purpose pair used in the design is not specified in the layer map file. Specify the layer-purpose pair in the layer map file and try again.
5.WARNING (XSTRM-34): The objects in the layer-purpose pair '73:3' are ignored. This is because either the layer-purpose pair used in the design is not specified in the layer map file or the layer/purpose is not defined in technology file. Ensure that the layer-purpose pair used in the design is specified in the layer map file and the layer/purpose is defined in technology file.
6.WARNING (XSTRM-35): The objects in the layer-purpose pair 'background:drawing' are ignored. This is because the layer-purpose pair used in the design is not specified in the layer map file. Specify the layer-purpose pair in the layer map file and try again.
7.WARNING (XSTRM-35): The objects in the layer-purpose pair 'changedLayer:tool0' are ignored. This is because the layer-purpose pair used in the design is not specified in the layer map file. Specify the layer-purpose pair in the layer map file and try again.
8.WARNING (XSTRM-145): The structure name 'g_padonly_VIA3' has been changed to 'g_padonly_VIA3_0' by the translator. This could be because multiple cells with the same cell name exist in different libraries, the same cell name has been mapped to multiple cell names, or the cell name length is greater than the '32' that was specified using the '-respectGDSIINameLimit' or '-gdsCellNameLength' option.
大家帮我看看 这些产生gds 文件后的警告信息 是否有任何问题,谢谢
发表于 2020-7-14 22:52:27 | 显示全部楼层
楼主解决了没
发表于 2022-8-29 11:02:49 | 显示全部楼层
请问楼主解决了么
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 05:17 , Processed in 0.016652 second(s), 6 queries , Gzip On, Redis On.
