在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1493|回复: 2
[求助] please help for VHDL code
发表于 2017-6-28 09:13:53 | 显示全部楼层 |阅读模式
I don't have much Vhdl coding experience, please help for the follow code
IO1 port is defined in component section
port(
IO1  : inout  std_logic_vector(31 downto 0);
at the time of calling this module, we have both RegPort_B and RegPort_C defined as output and input
respectively:
RegPort_B    : OUT std_logic_vector ( 15 DOWNTO 0);
RegPort_C    : IN  std_logic_vector (15 DOWNTO 0);
so IO1 as output I coded: in port map section
IO1 => noCon(15 downto 0) & RegPort_A(15 downto 0),
for an instance
and as input:
IO1  => B"0000000000000000" & RegPort_C(15 downto 0),
for another instance
but I got errors for both:
    55:       IO1  => B"0000000000000000" & RegPort_C(15 downto 0),
[Error] Actual must be a signal or port (or a type conversion on a signal or port)
and
    79:       IO1  => noCon(31 downto 16) & RegPort_B(15 downto 0)
[Error] Read error: trying to read port of mode OUT
please help
发表于 2017-6-29 14:25:26 | 显示全部楼层
有点乱,能否直接上代码部分的内容截图?感觉是inout接口在例化时候的连接问题。
发表于 2017-8-16 16:18:26 | 显示全部楼层
IO1将输入和输出分开定义
    IO1_in   : in std_logic_vector(31 downto 0);
    IO1_out : out  std_logic_vector(31 downto 0);
例化时在component外部进行三态控制。
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 12:36 , Processed in 0.022565 second(s), 6 queries , Gzip On, Redis On.
