RF AND MICROWAVE TRANSMITTER DESIGN[Andrei_Grebennikov].pdf
(10.76 MB, 下载次数: 654 )
作者简介Andrei Grebennikov is a Member of the Technical Staff at Bell Laboratories, Alcatel-Lucent, in Ireland. His responsibilities include the design and development of advanced highly efficient and linear transmitter architectures for base station cellular applications. He has taught at the University of Linz in Austria, the Institute of Microelectronics in Singapore, and the Moscow Technical University of Communications and Informatics. He has written over eighty scientific papers, has written four books, and is a Senior Member of IEEE. 目录Preface
Introduction
References
1 Passive Elements and Circuit Theory
1.1 Immittance Two-Port Network Parameters
1.2 Scattering Parameters
1.3 Interconnections of Two-Port Networks
1.4 Practical Two-Port Networks
1.5 Three-Port Network with Common Terminal
1.6 Lumped Elements
1.7 Transmission Line
1.8 Types of Transmission Lines
1.9 Noise
References
2 Active Devices and Modeling
2.1 Diodes
2.2 Varactors
2.3 MOSFETs
2.4 MESFETs and HEMTs
2.5 BJTs and HBTs
References
3 Impedance Matching
3.1 Main Principles
3.2 Smith Chart
3.3 Matching with Lumped Elements
3.4 Matching with Transmission Lines
3.5 Matching Networks with Mixed Lumped and Distributed Elements
References
4 Power Transformers, Combiners, and Couplers
4.1 Basic Properties
4.2 Transmission-Line Transformers and Combiners
4.3 Baluns
4.4 Wilkinson Power Dividers/Combiners
4.5 Microwave Hybrids
4.6 Coupled-Line Directional Couplers
References
5 Filters
5.1 Types of Filters
5.2 Filter Design Using Image Parameter Method
5.3 Filter Design Using Insertion Loss Method
5.4 Bandpass and Bandstop Transformation
5.5 Transmission-Line Low-Pass Filter Implementation
5.6 Coupled-Line Filters
5.7 SAW and BAW Filters
References
6 Modulation and Modulators
6.1 Amplitude Modulation
6.2 Single-Sideband Modulation
6.3 Frequency Modulation
6.4 Phase Modulation
6.5 Digital Modulation
6.6 Class-S Modulator
6.7 Multiple Access Techniques
References
7 Mixers and Multipliers
7.1 Basic Theory
7.2 Single-Diode Mixers
7.3 Balanced Diode Mixers
7.4 Transistor Mixers
7.5 Dual-Gate FET Mixer
7.6 Balanced Transistor Mixers
7.7 Frequency Multipliers
References
8 Oscillators
8.1 Oscillator Operation Principles
8.2 Oscillator Configurations and Historical Aspect
8.3 Self-Bias Condition
8.4 Parallel Feedback Oscillator
8.5 Series Feedback Oscillator
8.6 Push–Push Oscillators
8.7 Stability of Self-Oscillations
8.8 Optimum Design Techniques
8.9 Noise in Oscillators
8.10 Voltage-Controlled Oscillators
8.11 Crystal Oscillators
8.12 Dielectric Resonator Oscillators
References
9 Phase-Locked Loops
9.1 Basic Loop Structure
9.2 Analog Phase-Locked Loops
9.3 Charge-Pump Phase-Locked Loops
9.4 Digital Phase-Locked Loops
9.5 Loop Components
9.6 Loop Parameters
9.7 Phase Modulation Using Phase-Locked Loops
9.8 Frequency Synthesizers
References
10 Power Amplifier Design Fundamentals
10.1 Power Gain and Stability
10.2 Basic Classes of Operation: A, AB, B, and C
10.3 Linearity
10.4 Nonlinear Effect of Collector Capacitance
10.5 DC Biasing
10.6 Push–Pull Power Amplifiers
10.7 Broadband Power Amplifiers
10.8 Distributed Power Amplifiers
10.9 Harmonic Tuning Using Load–Pull Techniques
10.10 Thermal Characteristics
References
11 High-Efficiency Power Amplifiers
11.1 Class D
11.2 Class F
11.3 Inverse Class F
11.4 Class E with Shunt Capacitance
11.5 Class E with Finite dc-Feed Inductance
11.6 Class E with Quarterwave Transmission Line
11.7 Class FE
11.8 CAD Design Example: 1.75 GHz HBT Class E MMIC Power Amplifier
References
12 Linearization and Efficiency Enhancement Techniques
12.1 Feedforward Amplifier Architecture
12.2 Cross Cancellation Technique
12.3 Reflect Forward Linearization Amplifier
12.4 Predistortion Linearization
12.5 Feedback Linearization
12.6 Doherty Power Amplifier Architectures
12.7 Outphasing Power Amplifiers
12.8 Envelope Tracking
12.9 Switched Multipath Power Amplifiers
12.10 Kahn EER Technique and Digital Power Amplification
References
13 Control Circuits
13.1 Power Detector and VSWR Protection
13.2 Switches
13.3 Phase Shifters
13.4 Attenuators
13.5 Variable Gain Amplifiers
13.6 Limiters
References
14 Transmitter Architectures
14.1 Amplitude-Modulated Transmitters
14.2 Single-Sideband Transmitters
14.3 Frequency-Modulated Transmitters
14.4 Television Transmitters
14.5 Wireless Communication Transmitters
14.6 Radar Transmitters
14.7 Satellite Transmitters
14.8 Ultra-Wideband Communication Transmitters
References
Index |
