在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 62437|回复: 115
[原创] 分享我的h.264 decoder, Verilog源码与工程
发表于 2017-5-24 18:50:27 | 显示全部楼层 |阅读模式
分享我的h.264 decoder, verilog源码与工程。
这是我从2011年开始写的, 一开始只是支持640x480分辨率,在cyclone4 e40上的, 没有实现deblocking filter, 帧率也只有25fps。
最近接了个无人机h.264 FPGA解码的项目, 需要实现720p 60fps及的blocking filter,经过几个月的修改。终于完成了。
这里公开我原来在cyclone4 e40上的的的源码与工程, 和在米尔zturn zynq7020开发板及黑金zynq 7020上能解码720p 60fps的sd卡镜像,有板子的朋友可以试试。
下面是最新版本的datasheet,希望有项目合作的机会。
Function Overview.
Osenlogic OSD10receives the h.264 NAL stream from a fifo from external memory, and it decodesit to YUV 4:2:0, then store to external memory.
OsenLogic OSD10includes bitstream parser(expglomb and CAVLC), IDCT/Iquant(residual), Intrapredictor and inter predictor and deblocking filter.
All areimplemented in Verilog hdl. The decoder can work without cpu or with CPU.
block overview
block overview
3.Interface Signals
Signal Name
Direction
Description
rst_n
Input
Global reset
clk
Input
Main decoder clock
ext_mem_rd_clk
Input
The clock associated with the external memory reader
ext_mem_wr_clk
Input
The clock associated with the external memory writer
ena
Input
Enable the decoder
stream_mem_data_in
Input
The stream data from stream fifo
stream_data_valid
Input
High when stream data is avialible from stream fifo
stream_mem_rd
Output
High when the decoder request data from stream fifo
ext_mem_init_done
Input
High when external memory finished initialization
ext_mem_writer_burst
Output
Indicate the start of write burst
ext_mem_burst_len_minus1
Output
When ext_mem_writer_burst_len_minus1 is High, indicated the length of write burst
ext_mem_writer_ready
Input
High wehn external memory is able to accept data from memory
ext_mem_writer_addr
Output
Valid when ext_mem_writer_burst is high,indicate the address writing to external memory
ext_mem_writer_data
Output
The data from the decoder to external memory
ext_mem_writer_valid
Ouput
High wehn the data from the decoder is availible to external mem
ext_mem_reader_burst_ready
Input
High when external memory is ready to accept data from the decoder
Output
Indicate the start of read burst
ext_mem_reader_burst_len_minus1
Output
When ext_mem_reader_burst_len_minus1 is High, indicated the length of read burst
ext_mem_reader_ready
Output
High when decoder is able to accept data form exterl memory
ext_mem_reader_data
Input
Data being read from external memory
ext_mem_reader_valid
Input
High when external memory data is availible
pic_width_in_mbs
Output
Total MBs in width
pic_height_in_map_units
Output
Total MBs in height
total_mbs_one_frame
Output
Total MBs in frame
start_of_frame
Output
High when start of decoding frame
end_of_frame
Output
High when end of a decoding frame
pic_num
Output
Total decode frames
mb_index
Output
Current decoding mb_index
4.Specifications
Model
Osen Logic OSD10 h.264 decoder
Profile
Baseline
Level
3.1
Input Format
H.264 NAL stream
Output Format
YUV4:2:0
Slice type supported
I,SI,P,SP
Entropy Coding
CAVLC
Supported frme sizes
Max: 1920x1088
Min:640x480
Supported bitrate
0 to 10Mps
No decode rate control
Max supported resolution at max frame rate
1920x1088 @ 30fps, decoder clock working at 75M
Required external memory size
32Mbyte
External memory reader interface data width
64bit
External memory writer interface data width
32bit
Osenlogic_OSD10_datasheet.pdf
551.39 KB, 下载次数: 530 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2017-5-24 21:25:45 | 显示全部楼层
源码和sd卡镜像
myir zynq 7020或黑金ax7020播放1080p镜像, 可以用dd或
Win32DiskImager写入sd卡,sd >=2GB
bitstream.part1.rar
14 MB, 下载次数: 1209 , 下载积分: 资产 -5 信元, 下载支出 5 信元
bitstream.part2.rar
1.61 MB, 下载次数: 410 , 下载积分: 资产 -2 信元, 下载支出 2 信元
zturn264_trial.part001.rar
15 MB, 下载次数: 862 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part002.rar
15 MB, 下载次数: 921 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part003.rar
15 MB, 下载次数: 894 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part004.rar
15 MB, 下载次数: 850 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part005.rar
15 MB, 下载次数: 816 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part006.rar
zturn264_trial.part007.rar
15 MB, 下载次数: 763 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part008.rar
15 MB, 下载次数: 817 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part009.rar
15 MB, 下载次数: 785 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part010.rar
15 MB, 下载次数: 774 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part011.rar
15 MB, 下载次数: 747 , 下载积分: 资产 -5 信元, 下载支出 5 信元
zturn264_trial.part012.rar
9.35 MB, 下载次数: 387 , 下载积分: 资产 -4 信元, 下载支出 4 信元
ax7020_264_try.part001.rar
15 MB, 下载次数: 973 , 下载积分: 资产 -5 信元, 下载支出 5 信元
ax7020_264_try.part002.rar
15 MB, 下载次数: 993 , 下载积分: 资产 -5 信元, 下载支出 5 信元
ax7020_264_try.part003.rar
15 MB, 下载次数: 928 , 下载积分: 资产 -5 信元, 下载支出 5 信元
ax7020_264_try.part004.rar
15 MB, 下载次数: 968 , 下载积分: 资产 -5 信元, 下载支出 5 信元
ax7020_264_try.part005.rar
14.06 MB, 下载次数: 955 , 下载积分: 资产 -5 信元, 下载支出 5 信元
发表于 2017-5-24 22:56:57 | 显示全部楼层
回复 1# eebinqiu
     非常谢谢楼主的分享
发表于 2017-5-25 03:24:53 | 显示全部楼层
发表于 2017-5-25 09:00:25 | 显示全部楼层
楼主很强
发表于 2017-5-25 10:04:25 | 显示全部楼层
强。。。
发表于 2017-5-29 20:20:28 | 显示全部楼层
能贴出来就知道楼主很牛逼
发表于 2017-5-31 14:18:24 | 显示全部楼层
楼主,请问这个IP占多少FPGA资源?
 楼主| 发表于 2017-6-1 11:37:03 | 显示全部楼层
回复 8# anon1118
    zynq7020整个系统占70%,ip占57%,资源占的挺多的,但是并行度高,75M可完成1080p解码
发表于 2017-6-1 14:54:34 | 显示全部楼层
好东西必须得支持下
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 17:02 , Processed in 0.032738 second(s), 8 queries , Gzip On, Redis On.
