在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2314|回复: 1
[求助] assura-QRC load issue - no technology file
发表于 2017-5-6 03:28:45 | 显示全部楼层 |阅读模式
Tools version:
IC615.500.17 (32-bit)
assura 4.1_USR4_HF6
cadence extraction QRC -64bit version 12.1.1-p076
Issue:
When I passed LVS, and finished setup QRC, click assura-QRC from the QRC icon in the toolbar.
CIW shows the following message:
"RCX-Init Begin"
*WARNING* Form 'vuiRcxRunForm', scroll region 'vuiRCXFlowTab', field 'ruleSetField': Bad value "defualt".
   Cyclic value must be one in the list of choices.
"RCX-Init done"
The QRC window don't have technology selection.
Thank you very much. I am struggling for solving this issue for several days. I tried to updated the QRC version to PVS151, EXT151, EXT161. I also tried to updated to IC616.500. But they are not working at all.
IC616.500.14, QRC version 15.1.4-s005 and PVS version 15.10-p023 has been updated.
But the QRC menu in the toolbar has only one option "Load QRC menu..."
The CIW shows the following message:
"*WARNING* QRC_HOME environmental variable is set but UI can't locate correct QRC installation. In order to run UI in QRC compatibility mode you need to have QRC executables in your $PATH and QRC version should be 8.1 or greater."
Please help me solve it. Thank you very much. adj
发表于 2021-1-7 11:36:27 | 显示全部楼层
我也是这个问题,头痛啊
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 11:49 , Processed in 0.016855 second(s), 6 queries , Gzip On, Redis On.
