在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 1562|回复: 1
[招聘] Cadence上海 招聘高级产品验证工程师/产品工程师-数字后端
发表于 2017-4-7 18:13:18 | 显示全部楼层 |阅读模式
投递方式:
If you have interest , PLS send your update CV to job_china@cadence.com(简历投递格式:姓名+学校+申请职位+工作地点)
接受2017年优秀应届硕士、博士生。
高级产品验证工程师—数字后端
1.   Lead Product Validation Engineer
Position Description:
This PV engineer mainly works for advanced STA (Static Timing Analysis)and
DelayCal features validation:
1. Qualify delay calculation and timing analysis result in Innovus system.
2. Maintain comprehensive regression suites for monitoring STA & delayCalst abilities.
3. Upgrading regression cases to use advanced design node data and check the impact.
Position Requirements:
1. Master degree or bachelor degree with 2~3 years working experience.
2. Solid background knowledge in digital backend design, knowledge in STA or delayCal is a strong plus.
3. Be familiar with Linux system, and scripting skills with TCL or PERL or Shell.
4. Patient, and good responsibility.
5. Good communication in English and Chinese.
2.   Lead Product Validation Engineer
The engineer will work on Innovus QOR validation. Monitor flow QOR in weekly
basis, debug QOR issues deeply across whole implementation flow from placement to CTS and to post route optimization. Also need to debug synthesis flow depending on project demand. Also the engineer need to write scripts to improve efficiency.
2. Solid background knowledge in digital backend design.
3.   Product Validation Engineer II
This engineer will work in Encounter block implementation product validation team. The responsibilities include:
1.Assist in Cadence EDI development and validation Validate and maintain comprehensive unit and flow test cases for Encounter Digital Implementation System.
2.Develop test suites of the new features of EDI functions.
1. MS of EE/CS.
2. Digital IC design knowledge is necessary, statistic timing analysis knowledge is a strong plus.
3. Unix System knowledge, vi/TCL/TK/CSH/Perl will be plus.
4. Good communication in English and Chinese, good confidence and self-motivation.
高级产品工程师—数字后端
1. Product Engineer II
1. Design and develop cutting edge technologies of Encounter/Innovus, to address future and immediate customer requirements.
2. Collaborate with R&D and production validation team to deliver high quality software release.
3. Provide technical support and trainings for Cadence AP business.
4. Communicate with global cross-function team to create technical solutions and involve in customer engagement.
1. CS/EE MS with 1+years IC physical design experience.
2. Be familiar with ICback-end design flow, including place, route, clock tree synthesis and timing optimization.
3. Strong analysis/debug capability for technical issues.
4. Good team spirit and be able to work under pressure.
5. Good communication skill in English.
2. Lead Product Engineer
Job Description:
1. CS/EE MS with 3+years or PhD with 1+ years IC physical design experience.
3.   Principal Product Engineer
Job Description:
1. Design and develop power planning and power routing features in Innovus, to address future and immediate customer requirements.
2. Collaborate with R&D for the technical specification of new enhancements. Work with production validation team to deliver high quality software release.
1. CS/EE MS with 5+ years or PhD with3+ years IC physical design experience.
2. Power planning, routing or DRC fixing experience in design tape-out.
3. Be familiar with IC back-end design flow. Knowledge of LEF/DEF and advanced process node DRC rule is a plus.
4. Strong analysis/debug capability for technical issues.
5. Good team spirit and be able to work under pressure.
6. Good communication skill in English.
实习生—数字后端
1.   Intern-Product Validation
1.Assist in Cadence hierarchical and DB areas development and validation.
2.Validate and maintain comprehensive hierarchical/Database unit and flow test cases for Encounter Digital Implementation System.
3.Develop test suites of the new features of hierarchical and Database functional/flow solution.
1.MS or excellent undergraduate.
2.Digital IC design knowledge is necessary, statistic timing analysis knowledge is a strong plus.
3.Unix System knowledge, vi/TCL/TK/CSH/Perl will be plus.
4.Good communication in English and Chinese, good confidence and self-motivation.
发表于 2018-3-6 12:38:51 | 显示全部楼层
高端人才啊!
GMT+8, 2024-4-25 16:59 , Processed in 0.015955 second(s), 6 queries , Gzip On, Redis On.
