在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1387|回复: 2
Error while testing ams 13.1
发表于 2017-2-15 22:46:03 | 显示全部楼层 |阅读模式
Hi i try to test my installation of ams 13.1, but fail:
Simulating with Eldo...                                               PASS
Performing license checks:  verilogart                                PASS
Simulating with Eldo VerilogA                                         FAIL
when i look at logs i see:
from /var/tmp/systest_eldo_systest_dir_32047/DefaultVlogALib/_OS/aol/resistor.c:1:
/usr/include/string.h:544:5: error: expected declaration specifiers or '...' before '__locale_t'
/usr/include/string.h:545:6: error: nonnull argument with out-of-range operand number (argument 1, operand 3)
/usr/include/string.h:548:18: error: expected declaration specifiers or '...' before '__locale_t'
/usr/include/string.h:549:6: error: nonnull argument with out-of-range operand number (argument 1, operand 4)
How i can repair it? I try run ams 13.1 at CentOs 7.
发表于 2017-2-16 10:06:08 | 显示全部楼层
运行 LDD 或者strace 去查看需要哪些依赖的库
 楼主| 发表于 2017-2-16 13:38:35 | 显示全部楼层
If I understand correctly, this error occurred because of the fact that string.h newer than the distributions that are designed package.
Linear dynamic range show what libraries are needed package, I'm afraid it will not help here.
I checked the AMS 13 in SLED 10... and all works
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 10:33 , Processed in 0.022217 second(s), 6 queries , Gzip On, Redis On.
