在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 1315|回复: 1
[招聘] 美满电子(marvell)上海招聘数字电路设计以及验证工程师
发表于 2017-1-16 20:46:05 | 显示全部楼层 |阅读模式
诚聘数字电路设计/验证工程师, 有意者可将简历发送至 168vane@163.com
Job D
As  part of Marvell SOC design team, the engineer  will mainly focus on following areas, but  not limited to:
-Prepare architecture specification for IC circuits and  assist in ensuring correct circuit implementation.
  -RTL coding to verify  against circuit implementation; Perform integration into SOCs.
-Verify fucntions by creating test cases, and modify test benches to  work with internal simulation environment.
  -Develop test environments and analysis  coverage.
-Module and chip level synthesize with sdc/upf.
- Assist with chip bring up and perform silicon functional/perfornamce validation.
  -Define timing and power specifications, and identify timing solutions.
  -Assite with backend team on perform  place-and-route and timing analysis of modules
Required  Education, Knowledge, Skills & Abilities:
- Master’s degree in electrical  engineering, computer engineering or related technical fields
- Proven track record for successful design of IC products  in the past.
  - Good background in C, verilog, SystemVerilog and verification  methodology.
  - Knowledge and experience with Perl/Tcl and  Unix/Linux Makefile scripting strongly desired.
  - Knowledge in writing assertions, OVM/UVM, etc.
  - A high-level of self-motivation and a proactive approach to solving  problems.
  - Good English communications skills.
- arm cortex based low power processor is a plus
- Knowledge on wifi, 11 ac/ax is plus
发表于 2017-1-17 16:55:12 | 显示全部楼层
美满去年还是前年,裁员事件影响还在吧
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 08:21 , Processed in 0.017989 second(s), 8 queries , Gzip On, Redis On.
