在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
EETOP诚邀模拟IC相关培训讲师 创芯人才网--重磅上线啦!
查看: 2486|回复: 6
[讨论] acdc开关电源仿真
发表于 2017-1-12 10:03:46 | 显示全部楼层 |阅读模式
利用Cadence搭建acdc系统进行仿真,变压器不易模拟,能否为ACDC电路搭建buck系统,用以验证芯片功能。有没有利用这种方法仿真过的同仁,交流下。
发表于 2017-1-12 22:10:55 | 显示全部楼层
THANK YOU
 楼主| 发表于 2017-1-13 09:00:26 | 显示全部楼层
回复 2# nyne
   you are very very welcome
发表于 2017-1-13 15:42:54 | 显示全部楼层
    1. use veriloga model
   2. transformer model L add res
but hspice simulation long time
1~200ms 很花很花时间的
但是一会如此
代电感还很易不收敛拉
发表于 2017-1-16 15:04:17 | 显示全部楼层
感谢分享!
 楼主| 发表于 2017-1-16 16:48:03 | 显示全部楼层
回复 4# andy2000a
   I'm sorry, can you explain it more clearly, I can't catch up with you. How to use the transformer model, simply series a L and a RES to replace a winding?
How about to using a BUCK-TOP way to simulate the PSR switch ACDC IC which only test the function of IC?
Thanks very much.
发表于 2017-1-19 08:48:29 | 显示全部楼层
回复  andy2000a
   I'm sorry, can you explain it more clearly, I can't catch up with you. How  ...
elovu5256 发表于 2017-1-16 16:48
    floating buck some design for LED lighting ..
Just use inductor can simulation by hspice.
If you want to simulation flyback  . need transformer model
L1  n1 n2   xx
L2  n3 n4  xx
K12 l1 l2   0.997
GMT+8, 2024-4-26 05:07 , Processed in 0.027728 second(s), 8 queries , Gzip On, Redis On.
