在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 26647|回复: 36
Cadence Incisive 15.20.xxx imc组件 和谐 求交流
发表于 2016-10-15 09:39:59 | 显示全部楼层 |阅读模式
如题, 最近发现一个问题:
          Cadence incisive 15.10 以前的版本,用网上的破解imc可以正常启动。
   但是当更新到15.20以后的版本时imc启动报错,貌似是破解不全,各位大大有和谐方法请赐教~~
   以下是incisive 15.20.006版本启动IMC的报错log(linux系统版本: Ubuntu16.04):
*W,user_attr.import_by_path_not_supported: Import User Defined Attribute by VMANAGER_PATH is not supported. Please use Profile editor in order to import new user attributes.
Failed to acquire IMC Affirma_sim_analysis_env license
09:41:56:0575 [com.cadence.system] [main] FATAL - Failed - (LMF-03513): License call failed for feature Affirma_sim_analysis_env, version 15.2 and quantity 1. The license server search path is defined as /eda/Cadence_tools/crack/cadence_license_all.dat. The FLEXnet error message is as follows,
FLEXnet ERROR(-513, 4050, 0): Error List Returned (-513,4050) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ; Authentication Failed (-8,4048) ;
发表于 2016-10-15 15:40:36 | 显示全部楼层
回复 1# lxing_1988
   FLEXnet ERROR(-510, 3046, 0): Server's Feature Doesn't Authenticate On Client
之前的补丁都失效了
发表于 2016-10-30 20:14:52 | 显示全部楼层
回复 1# lxing_1988
   能upload 软件么
发表于 2017-4-1 15:55:28 | 显示全部楼层
回复 1# lxing_1988
IMC: 15.20-s020: (c) Copyright 1995-2017 Cadence Design Systems Inc 2017-02-11 21:52:50 cracked QQ图片20170401154449.png
 楼主| 发表于 2017-4-1 17:23:21 | 显示全部楼层
回复 4# designstart
   你好,大哥能说下怎么搞定的吗?
发表于 2017-4-10 18:34:12 | 显示全部楼层
怎么搞定的
发表于 2017-4-26 14:26:51 | 显示全部楼层
回复 1# lxing_1988
   搞定了没,我最近也在弄
发表于 2017-4-26 14:53:31 | 显示全部楼层
IMC did not work , but simvision 15.2 works fine.
23:50:13:0859 [com.cadence.system] [main] FATAL - Failed - (LMF-03513): License call failed for feature Affirma_sim_analysis_env, version 15.2 and quantity 1. The license server search path is defined as 5280@xxxx.
FLEXnet ERROR(-513, 7006, 0): Error List Returned (-513,7006) ; Server's Feature Doesn't Authenticate On Client Side (-510,3046) ; Server's Feature Doesn't Authenticate On Client Side (-510,3046)
It seems like the license server needs  Affirma_sim_analysis_env version 15.2 to run IMC.
发表于 2017-4-27 08:29:09 | 显示全部楼层
回复 8# spwedasd
   有这个feature,但是不能checkout
发表于 2017-4-27 10:08:20 | 显示全部楼层
回复 9# demonsolar
当启动simvision时,Affirma_sim_analysis_env功能也在服务器上验证,没有任何问题。
GMT+8, 2024-3-29 23:15 , Processed in 0.043622 second(s), 7 queries , Gzip On, Redis On.
