Linear Circuit Transfer Functions: An Introduction to Fast Analytical Techniques
Christophe P. Basso
Contents About the Author ix Preface xi Acknowledgement xiii 1 Electrical Analysis – Terminology andTheorems 1 1.1 Transfer Functions, an Informal Approach 1 1.1.1 Input and Output Ports 3 1.1.2 Different Types of Transfer Function 6 1.2 The Few Tools and Theorems You Did Not Forget . . . 11 1.2.1 The Voltage Divider 11 1.2.2 The Current Divider 12 1.2.3 Thévenin’s Theorem at Work 14 1.2.4 Norton’s Theorem at Work 19 1.3 What Should I Retain from this Chapter? 25 1.4 Appendix 1A – Finding Output Impedance/Resistance 26 1.5 Appendix 1B – Problems 37 Answers 39 2 Transfer Functions 41 2.1 Linear Systems 41 2.1.1 A Linear Time-invariant System 43 2.1.2 The Need for Linearization 43 2.2 Time Constants 44 2.2.1 Time Constant Involving an Inductor 47 2.3 Transfer Functions 49 2.3.1 Low-entropy Expressions 54 2.3.2 Higher Order Expressions 59 2.3.3 Second-order Polynomial Forms 60 2.3.4 Low-Q Approximation for a 2nd-order Polynomial 62 2.3.5 Approximation for a 3rd-order Polynomial 68 2.3.6 How to Determine the Order of the System? 69 2.3.7 Zeros in the Network 76 2.4 First Step Towards a Generalized 1st-order Transfer Function 78 2.4.1 Solving 1st-order Circuitswith Ease, Three Examples 82 2.4.2 Obtaining the Zero with the Null Double Injection 89 2.4.3 Checking Zeros Obtained in Null Double Injectionwith SPICE 94 2.4.4 Network Excitation 95 2.5 What Should I Retain from this Chapter? 100 References 101 2.6 Appendix 2A – Problems 102 Answers 105 3 Superposition and the Extra Element Theorem 116 3.1 The Superposition Theorem 116 3.1.1 A Two-input/Two-output System 120 3.2 The Extra Element Theorem 126 3.2.1 The EET at Work on Simple Circuits 130 3.2.2 The EET at Work – Example 2 132 3.2.3 The EET at Work – Example 3 137 3.2.4 The EET at Work – Example 4 138 3.2.5 The EET at Work – Example 5 140 3.2.6 The EET at Work – Example 6 146 3.2.7 Inverted Pole and Zero Notation 150 3.3 A Generalized Transfer Function for 1st-order Systems 153 3.3.1 Generalized Transfer Function – Example 1 156 3.3.2 Generalized Transfer Function – Example 2 159 3.3.3 Generalized Transfer Function – Example 3 163 3.3.4 Generalized Transfer Function – Example 4 170 3.3.5 Generalized Transfer Function – Example 5 174 3.4 Further Reading 180 3.5 What Should I Retain from this Chapter? 180 References 182 3.6 Appendix 3A – Problems 183 Answers 185 References 218 4 Second-order Transfer Functions 219 4.1 Applying the Extra Element Theorem Twice 219 4.1.1 Low-entropy 2nd-order Expressions 227 4.1.2 Determining the Zero Positions 231 4.1.3 Rearranging and Plotting Expressions 233 4.1.4 Example 1 – A Low-Pass Filter 235 4.1.5 Example 2 – A Two-capacitorFilter 241 4.1.6 Example 3 – A Two-capacitorBand-stop Filter 245 4.1.7 Example 4 – An LC Notch Filter248 4.2 A Generalized Transfer Function for 2nd-Order Systems 255 4.2.1 Inferring the Presence of Zeros in the Circuit 256 4.2.2 Generalized 2nd–order TransferFunction – Example 1 257 4.2.3 Generalized 2nd–order TransferFunction – Example 2 262 4.2.4 Generalized 2nd–order TransferFunction – Example 3 266 4.2.5 Generalized2nd–order TransferFunction – Example 4 273 4.3 What Should I Retain from this Chapter ? 277 References 279 4.4 Appendix 4A – Problems 279 Answers 282 References 311 5 Nth-order Transfer Functions 312 5.1 From the 2EET to the NEET 312 5.1.1 3rd-order Transfer Function Example 317 5.1.2 Transfer Functions with Zeros 320 5.1.3 A Generalized Nth-order Transfer Function 327 5.2 Five High-order Transfer Functions Examples 335 5.2.1 Example 2: A 3rd-order Active Notch Circuit 341 5.2.2 Example 3: A 4th-order LC Passive Filter 349 5.2.3 Example 4: A 4th-order Band-pass Active Filter 355 5.2.4 Example 5: A 3rd-order Low-pass Active GIC Filter 368 5.3 What Should I Retain from this Chapter ? 383 References 385 5.5 Appendix 5A – Problems 385 Answers 388 References 431 Conclusion 433 Glossary of Terms 435 Index 439
Linear Circuit Transfer Functions.part2.rar
(15 MB, 下载次数: 1621 )
Linear Circuit Transfer Functions.part3.rar
(11.87 MB, 下载次数: 1443 )
Linear Circuit Transfer Functions.part1.rar
(15 MB, 下载次数: 1625 )
