Proposal of a new lateral high-voltage n-channel MOS structure with a reduced parasitic output capacitance for a level-shift circuit integrated in 800 V-class high-voltage ICs
Highly reliable 1200-V p-type MOSFET for level-shift circuit used in driver IC
capacitive-loaded level shift circuit for improving the noise immunity of high voltage gate drive IC
Active level shift driver circuit and liquid crystal display apparatus including the same
4.5kV multi-chip level-shift circuit using dedicated discrete IGBTs for driving high-power IGBTs
Versatile high voltage level shift and driver for MEMS applications
只有
0.8um high-voltage IC using a newly designed 600V lateral P-channel dual-action device on SOI.pdf
(187.43 KB, 下载次数: 41 )
Dynamically Controlled Low-Power Level-up Shifter Operating up to 300V.PDF
(353.89 KB, 下载次数: 64 )
