在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: joseCAD
[SpyGlass][201606][Linux64][crack]
发表于 2016-8-9 12:16:27 | 显示全部楼层
Thank you very much!!!
It works very well.
发表于 2016-8-9 17:53:18 | 显示全部楼层
非常感谢,试过能起来
发表于 2016-8-9 20:29:06 | 显示全部楼层
謝謝.....
发表于 2016-8-9 20:41:22 | 显示全部楼层
支持发破解 便于学习
发表于 2016-8-10 17:00:26 | 显示全部楼层
回覆 1# joseCAD
    下來學習了
发表于 2016-8-13 21:58:27 | 显示全部楼层
回复 1# joseCAD
Thanks a lot
发表于 2016-9-7 12:58:43 | 显示全部楼层
"datasheet" and "dashboard" features do not work. So it's impossible to create reports.
发表于 2016-9-7 13:00:13 | 显示全部楼层
"datasheet" and "dashboard" features do not work. So it's impossible to generate reports.
发表于 2016-9-16 19:12:15 | 显示全部楼层
Getting the following message and error while running spyglass. Pls help me
WARNING : SpyGlass is only tested on Red Hat (Enterprise Linux release 5 and higher),
          Suse (version 10.0 and higher) and Ubuntu (version 14.04 LTS) flavors for Linux.
          Detected OS kernel version'(3.11.0-15-generic)' seems to be meeting the requirements,
          but detected OS flavor
          'Linux version 3.11.0-15-generic (buildd@akateko) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #25~precise1-Ubuntu SMP Thu Jan 30 17:42:40 UTC 2014 ' is not a tested OS flavor.
          SpyGlass run may have OS related issues specific to this distribution.
          Please contact Atrenta Support for any further queries in this regard.
FATAL : Missing executable `check.Linux2' at `/home/vinchip/Prabakaran_Files/Tools_inst/Spyglass_2016/SpyGlass-L2016.06/SPYGLASS_HOME/obj'
 楼主| 发表于 2016-9-17 12:01:31 | 显示全部楼层
回复 29# prabakaran_123
   I think your linux is not official supported by SG. You might change your linux OS to Red Hat Enterprise Linux. Of course, it take money. If you cannot, try to change some files. check.Linux4 is supported by RHEL. Go to spyglass installed dir/obj.ln -s check.Linux4 check.Linux2. If not working, you might be better to change your OS to RHEL5 or RHEL6.
GMT+8, 2024-4-25 14:37 , Processed in 0.029594 second(s), 8 queries , Gzip On, Redis On.
