在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
EETOP诚邀模拟IC相关培训讲师 创芯人才网--重磅上线啦!
查看: 1980|回复: 0
[求助] 谁有这篇文章_Novel high-voltage, high-side and low-side power devices
发表于 2016-7-1 17:00:58 | 显示全部楼层 |阅读模式
Qiao Ming~+,Fang Jian,Li Zhaoji,and Zhang Bo(College of Microelectronics and Solid-State Electronics,University of Electronic Science and Technology,Chengdu 610054,China)
A coupled level shift structure is designed and implemented.Compared with conventional S level shift structures,the two high electric fields of an LDMOS and a high voltage junction termination(HVJT) introduced by a high voltage interconnection(HVI) are avoided.The HV level shift and isolation of the high side and low side are directly coupled,so the chip size is reduced.The isolated resistor in the C level shift structure can be increased by a JFET consisting of a Pwell,Nepi,and P-sub,and the short of a poly field plate(PFP) in the LDMOS and HVJT is avoided by use of a metal field plate(MFP).Using HV single poly single metal(SPSM) CMOS DMOS(CD) technology developed by us,we experiment on a 1000V 3-phase power MOS gate driver circuit with C level shift structure successfully.The experimental results show that the maximal breakdown voltage of the C level shift structure is 1040V,which is 62.5% higher than that of a conventional S structure.The 1000V HVIC can be used for the HV application of AC220V and AC380V.
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 16:11 , Processed in 0.031751 second(s), 8 queries , Gzip On, Redis On.
