在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: liudin
SpyGl@ss 2016.06
发表于 2017-1-13 10:06:22 | 显示全部楼层
感谢分享试试、、
发表于 2017-1-13 16:13:18 | 显示全部楼层
thanks for sharing
发表于 2017-2-14 16:02:32 | 显示全部楼层
网盘给个把,谢谢!
发表于 2017-2-23 12:48:14 | 显示全部楼层
回复 1# liudin
  求问有没有SpyGlass tao(Timing and Optimization)的安装包
发表于 2017-4-7 09:36:25 | 显示全部楼层
谢谢啦,先下载下来,看看!
发表于 2017-10-11 15:00:20 | 显示全部楼层
谢谢啦,先下载下来,看看!
发表于 2018-1-12 08:20:36 | 显示全部楼层
回复 1# liudin
安装完后运行Spyglass就报下列错误, 我用debian 8和opensuse都报
   spyglass: INTERNAL-ERROR, the VALUE OF `$SPYGLASS_HOME' (an internal variable) was not intuited correctly.spyglass:                 The value guessed was: `SPYGLASS_HOME=/home/debian/APPSOFT/SpyGlass-L2016.06/SPYGLASS_HOME'
spyglass: INTERNAL-ERROR, the Perl 5 installation within `$SPYGLASS_HOME' could not be validated.
spyglass:                 A perl installation was expected at: `/home/debian/APPSOFT/SpyGlass-L2016.06/SPYGLASS_HOME/lib/multi-perl'
spyglass:                 either `$SPYGLASS_HOME' was guessed incorrectly or the installation is corrupted.
spyglass: NOTE, the caller's environment variable `$SPYGLASS_HOME' was ignored in this process.
发表于 2018-6-23 06:16:52 | 显示全部楼层
Hi friends,
This is for the the people facing error
spyglass:                 A perl installation was expected at: `/home/h/software/synopsys/SpyGlass-L2016.06/SPYGLASS_HOME/lib/multi-perl'
Solution:
I am assuming that you have configured $SPYGLASS_HOME variable.
This issue may be due to updated or latest linux kernel version 4.*.
Spyglass 2016 expects linux kernel version 3.
If you  want to use linux kernel version 4 then do two changes in scripts.
Please take backup of original files.
standard-environment.sh & perl files need to be modified.
1) Look for standard-environment.sh file in SPYGLASS_HOME/lib/SpyGlass. Open that file in text editor and search for Linux-3*. Add new entry Linux-4*) after fi ;; and before *)             echo UNKNOWN ;; . I have shown it below.
Linux-3*)
            if [ X"$switch32bit" = "Xyes" ]; then
                echo "Linux2"
            elif  [ X"$switch64bit" = "Xyes" ]; then
                PROCNAME=`uname -p`
                if [ "X$PROCNAME" = "Xunknown" ]; then
                    PROCNAME=`uname -m`
                fi
                if [ X"$PROCNAME" = "Xx86_64" ]; then
                    echo "Linux4"
                else
                    echo "Linux2"
                fi
            else
                PROCNAME=`uname -p`
                    PROCNAME=`uname -m`
                fi
                    if [ X"$defExeOn64Bit" = "X32" ]; then
                        echo "Linux2"
                    else
                        echo "Linux4"
                    fi
                else
                    echo "Linux2"
                fi
            fi
     Linux-4*)
                echo "Linux2"
                PROCNAME=`uname -p`
                    PROCNAME=`uname -m`
                fi
                    echo "Linux4"
                else
                    echo "Linux2"
                fi
            else
                PROCNAME=`uname -p`
                    PROCNAME=`uname -m`
                fi
                        echo "Linux2"
                    else
                        echo "Linux4"
                    fi
                else
                    echo "Linux2"
                fi
            fi
     *)             echo UNKNOWN ;;
2) After this open perl from root installation directory.
From that open "perl" script in text editor. Again look for Linux-3* and add following code after fi ;;
Linux-4*)      ##now we have Linux-64 bit also
            PROCNAME=`uname -p`
               PROCNAME=`uname -m`
            fi
                       species=Linux4
                    else
                       species=Linux2
                    fi
If you don't want to edit files then take backup of the files and then replace with attached file.
spyglass_exe_error_sol.tar.gz
17.22 KB , 阅读权限: 5 , 下载次数: 293 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2018-8-6 19:05:46 | 显示全部楼层
Thanks
发表于 2018-8-6 19:42:01 | 显示全部楼层
thanks.~~~
GMT+8, 2025-5-2 12:51 , Processed in 0.030426 second(s), 10 queries , Gzip On, MemCached On.
