小弟最近用上述GSMC13_Digital工艺库做数字后端的时候发现库的文件不全。 我用的是synopsys公司的ICC进行CTS时,因为库中没有.tluplus或者.itf以及mapfile导致无法继续。。。。
后端TECH文件夹只有以下的文件
不知道有没有前辈用过这个工艺库啊???
Tech File Release Notes
VeriSilicon GSMC 0.13um Library
* Version : 1.001
* Date : Nov.27, 2012
* Release Description :
* This is the 1.001 version VeriSilicon GSMC 0.13um Library Technology File directory.
* The files are applied to develop the library or applied together with the library
* when customers develop designs based on VeriSilicon products.
* Version history :
* Version Date Changes
* 1.001 Nov.27, 2012 1. Copied from v1.0
* 2. Version1.001 release
* 1.0 Jun.29, 2012 1. Version1.0 release
* 0.0 May.30, 2008 1. Version0.0 release
Files Description:
1. Following files are provided by VeriSilicon:
(1) Apollo/Astro technology files
gsmc13_apollo_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm4.tf (top metal is metal4)
gsmc13_apollo_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm5.tf (top metal is metal5)
gsmc13_apollo_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm6.tf (top metal is metal6)
gsmc13_apollo_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm7.tf (top metal is metal7)
(2) Apollo/Astro GDS layer mapping files
gdsLayers.map (stream in layer mapping file)
2. Following files are provided by GSMC:
(1) Calibre Antenna command files
GSMC_A013S7G0_ANT_DRC_Cal.cmd (top metal is metal4, 5, 6, 7)
(2) Calibre DRC command files
GSMC_A013S7G0_DRC_Cal.cmd (top metal is metal4, 5, 6, 7)
(3) Calibre LVS command files
GSMC_A013S7G0_LVS_Cal.cmd (top metal is metal4, 5, 6, 7)
(4) virtuoso tech file, mapping file and display file
GSMC_A013S7G0_Virtuoso_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.png500.tf
GSMC_A013S7G0_Virtuoso_500.map
GSMC_L013S8G0_display.drf
(5) Antenna clf files
GSMC_A013S4G0_ANT.clf (top metal is metal4)
GSMC_A013S5G0_ANT.clf (top metal is metal5)
GSMC_A013S6G0_ANT.clf (top metal is metal6)
GSMC_A013S7G0_ANT.clf (top metal is metal7)
3. Following files are VeriSilicon Virtuoso mapping file and tech file
gsmc13_opus_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm4.tf (top metal is metal4)
gsmc13_opus_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm5.tf (top metal is metal5)
gsmc13_opus_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm6.tf (top metal is metal6)
gsmc13_opus_file:///C:\Users\Mcgrady_shuo\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pngm7.tf (top metal is metal7)
gds2gsmc.map |
