Programming the Photon - Christopher Rush.pdf
(9.75 MB, 下载次数: 53 )
Quickly learn to construct your own electronics devices and control them over the Internet with help from this DIY guide. Programming the Photon: Getting Started with the Internet of Things features clear explanations and step-by-step examples that use inexpensive, easy-to-find components. Discover how to connect to Wi-Fi networks, attach hardware to I/O ports, write custom programs, and work from the cloud. You will learn how to troubleshoot and tweak your Photon creationseven interface with social media sites!
Set up your Photon board and connect to the Particle cloud
Start constructing and programming custom IOT projects
Learn the syntax of both the C and Arduino languages
Incorporate switches, sensors, and other input devices
Control hardware through the Photons outputs
Control your creations through the Internet
Add functions with Particle shields and add-on boards
Link real-time data to your board via the IFTTT Web Service
Integrate with websitesFacebook, Twitter, Gmail, and more! |
