在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2544|回复: 1
[求助] 求助!abstract打开library就报错,卡在这里好久了,请各位帮帮忙,不胜感激!
发表于 2016-4-18 15:03:16 | 显示全部楼层 |阅读模式
INV的layout
INV的layout
我用的是CSMC500nm的工艺
这是错误截图,可能看不清,说的是:Error: Valid Vias not present in interconnect section in the LEFDefaultRouteSpec constraintgroup.Add the Vaild Vias section in the interconnect section in the LEFDefaultRouteSpec constraintgroup or change the constraint group from File:GEneral Options section and try again.
INFO:Verifying Technology Data ...
Error: The A1 layer does not have a minimum winth.
Error: The A1 layer does not have a minimum spacing value defined.
Error: The routing direction for A1 is specified but no pitch value is present in the technology file.
A2 和 T3也是一样的错误,但我看了tf文件,是有定义的啊,详细内容我写了个文档,请大神指导一下,不胜感激!!!
physicalRules(
    mfgGridResolution(
        ( 0.005 )
    ) ;mfgGridResolution
    spacingRules(
;       ( rule            layer1                          layer2                          value            )
        ( minWidth        ("TB" "drawing")                                                2.5              )
        ( minNotch        ("TB" "drawing")                                                1.4              )
        ( minSpacing      ("TB" "drawing")                                                4.0              )
        ( minWidth        ("TO" "drawing")                                                0.5              )
        ( minNotch        ("TO" "drawing")                                                0.8              )
        ( minSpacing      ("TO" "drawing")                                                1.0              )
        ( minWidth        ("GT" "drawing")                                                0.5              )
        ( minNotch        ("GT" "drawing")                                                0.5              )
        ( minSpacing      ("GT" "drawing")                                                0.5              )
        ( minWidth        ("PC" "drawing")                                                1.0              )
        ( minNotch        ("PC" "drawing")                                                1.0              )
        ( minSpacing      ("PC" "drawing")                                                1.0              )
        ( minWidth        ("A1" "drawing")                                                0.6              )
        ( minNotch        ("A1" "drawing")                                                0.6              )
        ( minSpacing      ("A1" "drawing")                                                0.6              )
        ( minWidth        ("A2" "drawing")                                                0.7              )
        ( minNotch        ("A2" "drawing")                                                0.65             )
        ( minSpacing      ("A2" "drawing")                                                0.65             )
        ( minWidth        ("T3" "drawing")                                                1.5              )
        ( minNotch        ("T3" "drawing")                                                1.5              )
        ( minSpacing      ("T3" "drawing")                                                1.5              )
    ) ;spacingRules
    mfgGridResolution(
        ( 0.005 )
) ;physicalRules
[url=]abstract问题.docx[/url]
abstract问题.docx
103.44 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2016-4-21 13:15:16 | 显示全部楼层
我找到原因了,是因为没有save tech.db,所以我更改techfile.tf一直没用
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-23 21:31 , Processed in 0.022605 second(s), 9 queries , Gzip On, Redis On.
