在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2504|回复: 1
[求助] 安装完ius之后原先安装的questasim和verdi起不来了,why???
发表于 2016-3-23 21:10:03 | 显示全部楼层 |阅读模式
如题,修改之后,verdi起来了。但是vsim还是不行。难道是license,path冲突了???显示的是:
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license.  Vsim is closing.
** Fatal: Invalid license environment. Application closing.
运行lmutil lmdiag之后显示
[zxji@zxji ~]$ lmutil lmdiag
lmutil - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
FLEXlm diagnostics on Wed 3/23/2016 21:13
License file: /opt/verdi/license/license.dat
"Verdi" v2012.10, vendor: snslmgrd
  License server: zxji
  nodelocked license, locked to ethernet address "000c29b249c3"  starts: 22-mar-2016,   expires: 1-mar-2017
This license can be checked out
License file: /opt/cadence/ius/IUS09.20.007L1P1/IUS/license/license.dat
ERRORS: /opt/cadence/ius/IUS09.20.007L1P1/IUS/license/license.dat:line 1733:Invalid license file syntax.
Feature:       Verdi
License text:  31−dec−2005
License path:  /opt/verdi/license/license.dat:/opt/cadence/ius/IUS09.20.007L1P -
FLEXnet Licensing error:-2,6
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
/opt/cadence/ius/IUS09.20.007L1P1/IUS/license/license.dat:line 1734:Invalid license file syntax.
Feature:       Verdi
"Cadence_3D_Design_Viewer" v16.0, vendor: cdslmd
  uncounted nodelocked license locked to NOTHING (hostid=ANY)  expires: 31-dec-2025
This is the correct node for this node-locked license
没有vsim的license文件!!!(没装ius之前vsim verdi都能正常启动,怎么会没有license)
到底是什么原因啊!!困扰了好几天了,,,
发表于 2017-3-2 17:03:23 | 显示全部楼层
gooooooooooooooooooooooooooooooooooood
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-18 12:42 , Processed in 0.021004 second(s), 9 queries , Gzip On, Redis On.
