在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 1965|回复: 1
[求助] 安装verdi3——201210时遇到的问题,求大神帮忙解决
发表于 2016-3-20 11:07:41 | 显示全部楼层 |阅读模式
0:58:52 (lmgrd) The license server manager (lmgrd) running as root:
10:58:52 (lmgrd)
This is a potential security problem
10:58:52 (lmgrd)
and is not recommended.
[root@zxji verdi]# 10:58:52 (lmgrd) FLEXnet Licensing (v11.6.0.0 build 60117 i86_re3) started on zxji (linux) (3/20/2016)
10:58:52 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
10:58:52 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:58:52 (lmgrd) World Wide Web:  http://www.acresso.com
10:58:52 (lmgrd) License file(s): /opt/verdi/license/license.dat
10:58:52 (lmgrd) lmgrd tcp-port 28001
10:58:52 (lmgrd) Starting vendor daemons ...
10:58:52 (lmgrd) Started snslmgrd (internet tcp_port 49904 pid 3528)
10:58:52 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:52 (snslmgrd) Server started on zxji for:
Verdi
10:58:52 (snslmgrd) EXTERNAL FILTERS are OFF
10:58:53 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:58:53 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:58:53 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:58:53 (lmgrd) Since this is an unknown status, license server
10:58:53 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:58:53 (lmgrd) REStarted snslmgrd (internet tcp_port 37669 pid 3574)
10:58:53 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:53 (snslmgrd) Server started on zxji for:
Verdi
10:58:53 (snslmgrd) EXTERNAL FILTERS are OFF
10:58:54 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:58:54 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:58:54 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:58:54 (lmgrd) Since this is an unknown status, license server
10:58:54 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:58:54 (lmgrd) REStarted snslmgrd (internet tcp_port 49743 pid 3621)
10:58:54 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:54 (snslmgrd) Server started on zxji for:
Verdi
10:58:54 (snslmgrd) EXTERNAL FILTERS are OFF
10:58:55 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:58:55 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:58:55 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:58:55 (lmgrd) Since this is an unknown status, license server
10:58:55 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:58:55 (lmgrd) REStarted snslmgrd (internet tcp_port 41241 pid 3667)
10:58:55 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:55 (snslmgrd) Server started on zxji for:
Verdi
10:58:55 (snslmgrd) EXTERNAL FILTERS are OFF
10:58:56 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:58:56 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:58:56 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:58:56 (lmgrd) Since this is an unknown status, license server
10:58:56 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:58:56 (lmgrd) REStarted snslmgrd (internet tcp_port 51128 pid 3713)
10:58:56 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:56 (snslmgrd) Server started on zxji for:
Verdi
10:58:56 (snslmgrd) EXTERNAL FILTERS are OFF
10:58:57 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:58:57 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:58:57 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:58:57 (lmgrd) Since this is an unknown status, license server
10:58:57 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:58:57 (lmgrd) REStarted snslmgrd (internet tcp_port 60560 pid 3759)
10:58:57 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:57 (snslmgrd) Server started on zxji for:
Verdi
10:58:57 (snslmgrd) EXTERNAL FILTERS are OFF
10:58:58 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:58:58 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:58:58 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:58:58 (lmgrd) Since this is an unknown status, license server
10:58:58 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:58:58 (lmgrd) REStarted snslmgrd (internet tcp_port 46376 pid 3805)
10:58:58 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:58 (snslmgrd) Server started on zxji for:
Verdi
10:58:58 (snslmgrd) EXTERNAL FILTERS are OFF
10:58:59 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:58:59 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:58:59 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:58:59 (lmgrd) Since this is an unknown status, license server
10:58:59 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:58:59 (lmgrd) REStarted snslmgrd (internet tcp_port 40778 pid 3851)
10:58:59 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:58:59 (snslmgrd) Server started on zxji for:
Verdi
10:58:59 (snslmgrd) EXTERNAL FILTERS are OFF
10:59:00 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:59:00 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:59:00 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:59:00 (lmgrd) Since this is an unknown status, license server
10:59:00 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:59:00 (lmgrd) REStarted snslmgrd (internet tcp_port 41328 pid 3897)
10:59:00 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:59:00 (snslmgrd) Server started on zxji for:
Verdi
10:59:00 (snslmgrd) EXTERNAL FILTERS are OFF
10:59:01 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:59:01 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:59:01 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:59:01 (lmgrd) Since this is an unknown status, license server
10:59:01 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:59:01 (lmgrd) REStarted snslmgrd (internet tcp_port 35841 pid 3943)
10:59:01 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:59:01 (snslmgrd) Server started on zxji for:
Verdi
10:59:01 (snslmgrd) EXTERNAL FILTERS are OFF
10:59:02 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:59:02 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:59:02 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:59:02 (lmgrd) Since this is an unknown status, license server
10:59:02 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
10:59:02 (lmgrd) REStarted snslmgrd (internet tcp_port 33637 pid 3989)
10:59:02 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
10:59:02 (snslmgrd) Server started on zxji for:
Verdi
10:59:02 (snslmgrd) EXTERNAL FILTERS are OFF
10:59:03 (snslmgrd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
10:59:03 (snslmgrd) EXITING DUE TO SIGNAL 37 Exit reason 5
10:59:03 (lmgrd) snslmgrd exited with status 37 (Communications error)
10:59:03 (lmgrd) Please correct problem and restart daemons
发表于 2016-3-20 18:19:26 | 显示全部楼层
大神 跪求安装的synosys vcs 教程  最好还有安装包  在论坛里下了好多个 各种安装不了。。呜呜   我是小菜比一个 。。。。
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-18 11:57 , Processed in 0.022694 second(s), 8 queries , Gzip On, Redis On.
