在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 9686|回复: 21
[原创] Quartus 14.1 modelsim decryption keys
发表于 2016-3-12 04:20:03 | 显示全部楼层 |阅读模式
Appended is the Quartus 14.1 Decryption Key.
----- BEGIN RSA PRIVATE KEY -----
MIICXgIBAAKBgQC38SzR8u6xw1MKRDQPrZOyQMAXID + / lBTN7Dl2bl25 ++ tbKUcQ
kVMo6ZkCnt1WZ / wT22X7I5aTkagn6vpAXR8XQBu3san + chVulnr2p1Qxe1GVm5tt
4jCgCfr0BWNfHXWLwE0yBXR9 + zvaatCWb0WpS1UN5eqofIisn8Hj2ToOdQIDAQAB
AoGAKRh2 / Qkbjxemi9qlDwOmxeJ1iDUqSPEanM80H2OVCSJheOKGAAuX2sIl71Hy
/ YUJ6p3P8QYIdDvMp + 51rr + fXD8OiQdfWdHETb4G4wQCfpjIu549OQTWWRI0UIzn
EZQkWAJgZtwLE0rFjHdyEKxVZjiE3U7wHtD5ETvw9RZIK9kCQQDuhn9XKGYVV35v
YXbjFLKDABmWLj / tfDcFHRrwNZnUa4Sh7tG5FjGZOQXp2xp / wNg1Uz / 6RH722LUT
nK7GpuVHAkEAxWr6N5oEUtgIYTSLx6YC4au6xYaCXgoDZIO49f58UjO96xBFb2hG
nabO0lHm9yP7HmpTkj8C3RL + EZ1N19d8YwJBANnyhWqzXEvF7Z6CVSp7H / 35WmfS
jNFIPdHrXVD9 + TiSodeBK5rOf7V82D1t2dG / + Q8IqZ3ZdpXBP / vSoBSeLUMCQQCC
PxASOvT7SzhMGYTXFXn1NX2l8BZ2wJh4akdPVLTk7uov + a410FA2luUA8bQ1 / XEi
Ifg9FoFnJa6mJGhFLRANAkEAjUwGtyrKIwGhFsMdOPk36i6FogDTBd + yx7VsuUqL
bi3vEWInHekREOq7eLm3QSFGixw1Ayc7KC1UIdcYs6fI2g ==
----- END RSA PRIVATE KEY -----
(Remove spaces by hand)
To use it do the following: the search for rsa encrypted "keyblock" Part.
It is a 2-Liner base64 Copy it to a text file, ie
altera_lvds_pll.v.key.txt
Then search for the encrypted aes128-cbc "DataBlock" and Copy it for instance
into altera_lvds_pll.v.block.txt.
Then:
openssl rsa -text -IN MGC-DVT-MTI.pem;
cat altera_lvds_pll.v.key.txt | base64 -d > altera_lvds_pll.v.key.txt.bin;
openssl rsautl -decrypt -inkey $$ {d} -IN altera_lvds_pll.v.key.txt.bin .pem -out altera_lvds_pll.v.key.txt.bin.dec;
cat altera_lvds_pll.v.block.txt | base64 -d> altera_lvds_pll.v.block.txt.bin;
Key = `xxd -p altera_lvds_pll.v.key.txt.bin.dec`;
cat altera_lvds_pll.v.block.txt. bin | openssl AES-128-cbc IV 0 -K -d $ Key> altera_lvds_pll.dec.v;
cat altera_lvds_pll.dec.v;
MGC-DVT-MTI.pem.gz
731 Bytes, 下载次数: 390 , 下载积分: 资产 -2 信元, 下载支出 2 信元
modelsim key
发表于 2016-3-14 09:21:17 | 显示全部楼层
大神级!!!!
发表于 2016-3-14 16:28:37 | 显示全部楼层
  hao hao hao
发表于 2016-4-12 13:13:19 | 显示全部楼层
This is good stuff.
发表于 2016-4-13 11:15:52 | 显示全部楼层
MGC-DVT-MTI.pem.gz (731 Bytes)
下载次数:30
2016-3-12 14:45
下载需要消耗: 2 信元,如果是重复下载只需消耗: 1信元
modelsim key
发表于 2016-5-11 21:07:13 | 显示全部楼层
感谢楼主共享
发表于 2016-7-8 06:17:30 | 显示全部楼层
THANK YOU
发表于 2016-7-21 10:19:06 | 显示全部楼层
回复 1# kambodian
   哇哦,怎么做到的,求教
发表于 2017-3-14 16:59:36 | 显示全部楼层
thanks for this
发表于 2017-3-14 17:13:51 | 显示全部楼层
非常不错。。。。
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 06:22 , Processed in 0.031152 second(s), 8 queries , Gzip On, Redis On.
