Cadence 上海急招以下两个岗位,有意者请将简历发至541515639@qq.com。
1. Lead PV Engineer -Sigrityand Allegro PCB SI (Location: SH)
Position Description: Introduction Ø
We are lookingfor a signal integrity engineer with 1-5 years of experience in High Speeddesign. You will be responsible for testing and overseeing the qualitymanagement of our family of software products that deal with SI design.
Duties Ø
You will workwithin a global multi-functional team to review project plans and functionalspecifications, develop test criteria and written test plans, manually exerciseand test functionality of the Allegro PCB SI and Sigrity products and developautomated tests within the existing test environment. As this position requiresa good understanding of the signal integrity knowledge. You will maintainregression tests and evaluate results on a regular basis.
Position Requirements: Requirements Ø
BS Degree isrequired, MS is preferred Ø
Workingexperience with the Sigrity tools is strongly desired Ø
Solidunderstanding of the following: signal integrity, modeling and simulation Ø
Recentexperience with signal integrity tool is a must Ø
Knowledge ofother PCB design, routing, and packaging is a plus
Experience Ø
Knowledge ofWindows and Linux platforms is essential Ø
Any experiencein software validation Ø
Programmingknowledge in Perl is strongly desired Ø
Experience withan error tracking and reporting product is valuable
Basic Abilities Ø
Strong writtenand verbal communication skills, in English and Chinese are mandatory as thecandidate will be interacting with a global team based in the US and China. Ø
Ability tofollow a schedule is essential Ø
Familiarity withsoftware development life cycle is a plus Ø
Ability todetect, report and explain defects effectively is crucial Ø
Possess goodanalytical, problem solving skills Ø
Understand testprocesses and methodologies in a software development environment Ø
Self-starter,self-sufficient, able to work independently as well as with teams, able tomultitask
2. Lead PV Engineer -Sigrityand Allegro PCB (Location: SH)
We are looking for athermal engineer with 3+ years of experience in Thermal Analysis. You will beresponsible for testing and overseeing the quality of a software product thatdeal with System Level Thermal Solution. Duties Ø
You will work within a global multi-functional team toreview project plans and functional specifications, develop test criteria andwritten test plans, manually exercise and test functionality of the Sigrityproducts and develop automated tests within the existing test environment. Thisposition requires a good understanding of the thermal and mechanical knowledge.You will maintain regression tests, evaluate results on a regular basis andwork closely with the software developers. Position Requirements: Ø
B.S. degree required, M.S. preferred Ø
Experience with thermal, CFD and mechanical softwarea must Ø
Strong technical background in heat transfer, fluidmechanics, and circuit simulation Ø
Solid knowledge of package thermal characterization,compact thermal models, and thermal management of electronic devices andsystems. Ø
Working experiencewith 3-D CAD software and application Experience Ø
Experience in software validation is essential Ø
Knowledge of Windows and Linux platforms is must Ø
Experience with an error tracking and reportingproduct is valuable Ø
Familiaritywith software development life cycle is a plus Basic Abilities Ø
Strong written and verbal communication skills, in Englishand Chinese are mandatory as the candidate will be interacting with a globalteam based in the US and China. Ø
Ability to follow a schedule is essential Ø
Ability to detect, report and explain defectseffectively is crucial Ø
Possessing good analytical, problem solving skills Ø
Understanding test processes and methodologies in asoftware development environment Ø
Multitasking and working independently as well aswith teams as a self-sufficient self-starter |
