在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 7869|回复: 1
【求助】自制xilinx下载线遇到问题。cannot find cable,check cable setup
发表于 2015-9-16 11:55:41 | 显示全部楼层 |阅读模式
按照这个博客中的资料,我自制了XILINX的下载线。
  http://comm.chinaaet.com/adi/blogdetail/34431.html
  板子焊接完了,EEPROM固件程序也已成功下载,电脑能够识别下载线,设备管理器中显示xilinx USB cable。如下图
  但在使用IMPCT更新CPLD固件的时候遇到了问题,如下图
  IMPCT的console中错误信息如下图
  有人遇到过这样的问题吗?请留言帮助,不胜感激!
  以下附console的全部日志内容
  Welcome to iMPACT
iMPACT Version: 13.4
// *** BATCH CMD : setMode -bs
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusbdfwu.sys found.
Driver version: src=1027, dest=1027.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
Type = 0x0004.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
write cmdbuffer failed 20000015.
Error reading reference voltage level.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
PROGRESS_END - End Operation.
Elapsed time =     12 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
发表于 2016-9-12 22:39:33 | 显示全部楼层
速度太高?
GMT+8, 2024-3-29 05:31 , Processed in 0.020004 second(s), 10 queries , Gzip On, Redis On.
