在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: xykix325
[WIN] HSPICE J-2014 + License + Installation guide
 楼主| 发表于 2015-9-20 23:26:58 | 显示全部楼层
 楼主| 发表于 2015-9-20 23:28:33 | 显示全部楼层
I dont have enough disk space for Baidu Pan. Only 5gb. Mind give me link to get 2TB??
发表于 2015-9-21 08:20:39 | 显示全部楼层
回复 32# xykix325
做任务好像就能拿2T的空间
 楼主| 发表于 2015-9-21 09:58:11 | 显示全部楼层
Hi, thanks. For 2015 version, Synopsys wrote that it require scl11.9. I havent got time to  ...
xykix325 发表于 2015-9-20 23:26
   Works with SCL 11.9 and above only. Tested!
 楼主| 发表于 2015-9-21 09:59:41 | 显示全部楼层
回复  xykix325
做任务好像就能拿2T的空间
wayne19910320 发表于 2015-9-21 08:20
Will my files removed by Baidu by sharing these? I upload here because they didnt remove the files. I have limited internet quota to upload many times.
发表于 2015-9-21 10:39:26 | 显示全部楼层
回复 34# xykix325
   Is that the same installation guide and license with version 2014?   If so, I'm gonna try to install the version 2015.
    Thanks for your testing!
发表于 2015-9-21 11:06:44 | 显示全部楼层
回复 35# xykix325
   分享带提取码的一般不会的
 楼主| 发表于 2015-9-21 18:33:26 | 显示全部楼层
回复  xykix325
   Is that the same installation guide and license with version 2014?   If so,  ...
bjkjerry 发表于 2015-9-21 10:39
Yes, the same guide except you have to use Synopsys Common Licensing (SCL) 11.9 to use the license. You can search in the forums or wait for me to upload it.
发表于 2015-9-21 19:01:41 | 显示全部楼层
回复 38# xykix325
   I have installed the 2015 version with SCL 11.9 successfully!
Truly appreciate your installation guide! Very clear,easy, and helpful!
发表于 2015-9-22 04:01:04 | 显示全部楼层
Thank you for sharing.
GMT+8, 2024-3-29 17:46 , Processed in 0.036077 second(s), 6 queries , Gzip On, Redis On.
