在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 4641|回复: 8
Cadence IC6.1.6-64b.500.12 crash
发表于 2015-8-20 14:51:11 | 显示全部楼层 |阅读模式
Hi.
I installed the newest Cadence IC616 virtuoso version (
IC6.1.6-64b.500.12) and patched it with cadence_2013 patch.
Virtuoso crashes with this report (which seems to be related to the patched part of the code since it reports on license check-out procedures)
warning:44:*WARNING* Process was terminated with SIGSEGV signal
signal_by:system
stack:libpthread.so.0:__restore_rt+0()
stack:libc.so.6:__strcpy_sse2_unaligned+551()
stack:virtuoso:cds_pl_check+3229()
stack:virtuoso:inflate_fast+2988()
stack:virtuoso:cdspInit+1268()
stack:virtuoso:TE_lmCheckOut+250()
stack:virtuoso:icLicLocalCheckOut(char const*, double, int, int, int, int (*)(char const*, double, int, int, int, int))+313()
stack:virtuoso:icLicCheckOut+37()
stack:virtuoso:_dbGetLicense+86()
stack:virtuoso:dbiInit+27()
stack:libil_sh.so:iliInitClients+1112()
stack:virtuoso:main+622()
stack:libc.so.6:__libc_start_main+245()
stack:virtuoso:_start+41()
Has anyone seen this? I tried both on OpenSUSE 13.2 and Ubuntu 14.04 and it crashes on both.
Other software like latest MMSIM14.10.765 is pached OK and working
 楼主| 发表于 2015-8-23 18:29:45 | 显示全部楼层
Just checked even newer version -  IC6.1.6-64b.500.13
ALSO CRASHES !!!
Can please anyone help with this?
发表于 2015-8-30 21:26:15 | 显示全部楼层
我的也一样哦:
userenv:_=*5282*/home/zrway/tool/IC616/tools/dfII/bin/64bit/virtuoso
userenv:__DFII_INTEG_NC_PATH__=/home/zrway/tool/IC616/tools/inca/bin/64bit
userenv:_dfII_bin_bit=/64bit
userenv:df2BaseVhdlin=/home/zrway/tool/IC616
xdpyinfo:name of display:    :0
xdpyinfo:version number:    11.0
xdpyinfo:vendor string:    The X.Org Foundation
xdpyinfo:vendor release number:    11500000
xdpyinfo:X.Org version: 1.15.0
xdpyinfo:maximum request size:  16777212 bytes
xdpyinfo:motion buffer size:  256
xdpyinfo:bitmap unit, bit order, padding:    32, LSBFirst, 32
xdpyinfo:image byte order:    LSBFirst
xdpyinfo:number of supported pixmap formats:    7
xdpyinfo:supported pixmap formats:
xdpyinfo:    depth 1, bits_per_pixel 1, scanline_pad 32
xdpyinfo:    depth 4, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 8, bits_per_pixel 8, scanline_pad 32
xdpyinfo:    depth 15, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 16, bits_per_pixel 16, scanline_pad 32
xdpyinfo:    depth 24, bits_per_pixel 32, scanline_pad 32
xdpyinfo:    depth 32, bits_per_pixel 32, scanline_pad 32
xdpyinfo:keycode range:    minimum 8, maximum 255
xdpyinfo:focus:  window 0x1600007, revert to Parent
xdpyinfo:number of extensions:    27
xdpyinfo:    BIG-REQUESTS
xdpyinfo:    Composite
发表于 2015-8-30 21:34:44 | 显示全部楼层
怎么解决的,我的也一样。
 楼主| 发表于 2015-9-17 19:34:42 | 显示全部楼层
I don't know what is the solution. I guess it should be a fixed patch
发表于 2015-12-5 20:52:09 | 显示全部楼层
I heard 6.1.7 is available and the old patch works with this version - anyone try????
发表于 2016-1-11 20:27:41 | 显示全部楼层
same problem!
发表于 2016-1-20 09:08:54 | 显示全部楼层
thanks me boy
发表于 2016-3-31 09:27:38 | 显示全部楼层
gddddsdafasd
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-24 09:08 , Processed in 0.036515 second(s), 10 queries , Gzip On, Redis On.
