楼主 |
发表于 2015-7-27 10:35:44
显示全部楼层
回复 5# 真我个性
Presto compilation completed successfully.
Loading db file '/home/soc_test/ss/libraries/syn/dw_foundation.sldb'
Elaborated 1 design.
Current design is now 'Mon'.
Information: Building the design 'dsp_0000'. (HDL-193)
这是其中的log, 这应该是表名读进去dw_foundation.sldb了吧。
但是后面还报
Information: Building the design 'DW02_mult_3_stage' instantiated from design 'dsp_0000' with
the parameters "16,16". (HDL-193)
Warning: Cannot find the design 'DW02_mult_3_stage' in the library 'WORK'. (LBR-1)
Warning: Design 'Mon' has '4' unresolved references. For more detailed information, use the "link" command. (UID-341)
Current design is 'Mon'.
这是为何啊,求指教啊 |
