在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: saigu
[求助] FPGA+外部PHY+SFP光口问题
发表于 2015-7-16 19:04:13 | 显示全部楼层
sfp的6脚需接地
 楼主| 发表于 2015-7-16 19:42:52 | 显示全部楼层
回复 18# livelei
   嗯,谢谢!
发表于 2015-7-16 19:45:39 | 显示全部楼层
PHY有一部分引脚需要悬空,光部分调同了吗
 楼主| 发表于 2015-7-16 19:52:47 | 显示全部楼层
回复 20# 右手边
1. 是我原理图上的C113吗?从手册上看是需要连电容的。
2.6脚是MOD-DEF0,从手册上看,这个引脚在SFP内部是接地的,然后外面是直接连FPGA,然后拉高,如果有SFP插进来,这个引脚电压就会为0,说明有设备在了。
发表于 2015-7-16 20:05:03 | 显示全部楼层
第二句话你看看,no  connect。它是有两种供电方式。
发表于 2015-7-17 03:45:52 | 显示全部楼层
if LOS is high you are not driving laser on remote end or optical cable wrong
make sure other end is ON
Also check power pins L3/L4/L5/L6 to your SFP cage
Is the U11/U8 pattern correct on the PCB ?
strictly you need 1000-X not SGMII but that's another issue not related
发表于 2015-7-17 03:48:55 | 显示全部楼层
one other thing - is this optical SFP or "RJ45 SFP" ?
on Copper RJ45 SFP's the LOS does not work exactly as one can expect, it's either always ON or wired to internal PHY link status
发表于 2015-7-17 08:29:08 | 显示全部楼层
相信你能调通,到时什么原因说下
 楼主| 发表于 2015-7-17 08:47:18 | 显示全部楼层
回复 28# 右手边
   谢谢,到时候调通肯定会贴出原因的。
 楼主| 发表于 2015-7-17 09:20:57 | 显示全部楼层
回复 26# anovickis
How can i drive the laser on remote end? Two PCBs are connected with SFP which is powered by PCB, and does it means that the end is on?
RJ-45 SFP is been tested and two PCBs can communicate with each other. When i change the RJ-45 sfp with optical sfp, the two PCBs can not work.
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 04:30 , Processed in 0.029372 second(s), 7 queries , Gzip On, Redis On.
