talk about freeware GDS viewer tool
layout editor -- freeware,界面漂亮,有许多功能,但 1G file run 不起来,若是小档案,还是可以一试
KLayout -- freeware,界面普普,功能简单,1G file 跑得起来,速度在中上,是我试验过的软件中速度最好的
Owlvision -- freeware,界面普普,须事先装 java 平台,1G file run 不起来
SoCgds -- Dolphin integration 出品的 freeware,但新版软件有问题,旧版 ok,1G file run 不起来,界面中上
Coolview -- shareware,有 45天使用限制,可以 run 1G file,界面可接受,可 import lef and def file,如果没有使用期限限制,会是我第二选择
By chip123 阿光
UQ GDSII Viewer need Java
NanoViewer by nanotech need online license -> simple and small
GLADE Glade (Gds, Lef And Def E ditor), is a freeware IC layout editor from Peardrop Design Systems capable of reading GDS2, OASIS, LEF and DEF plus a few other formats. It can load and display large design databases with its fast
=> run XP 32bit fail lack of msvcp20.dll msvcr120.dll -> run work ..good |
