在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 5039|回复: 15
谁有bda afs lic 模板?准备把它XX了
发表于 2015-4-17 14:02:17 | 显示全部楼层 |阅读模式
 楼主| 发表于 2015-4-18 12:44:46 | 显示全部楼层
没人理我,自己搞定了
发表于 2015-4-18 13:16:27 | 显示全部楼层
Trying to acquire 1 AFS Nano license(s) for invocation
Acquired AFS Nano license
* Version: AFS 64-bit (2014_Q2)                                                  *
* Build date: Wed May 28 16:36:33 PDT 2014                                       *
* User: linux, Host: solaris.localdomain, Proc id: 1980                          *
* Working Directory: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna *
* OS: Linux, Machine Type: x86_64                                                *
* Copyright 2004-2014 Mentor Graphics Corporation                                *
* All Rights Reserved.                                                           *
* THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION                    *
* WHICH ARE THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS                   *
* LICENSORS AND IS SUBJECT TO LICENSE TERMS.                                     *
Job Start Time: Mon Sep 15 23:20:17 2014
***** Command-Line Options
afs lna_dna_advisor.scs -f psfbin -o lna_dna_advisor.psfbin -l lna_dna_advisor.log
***** Memory Information
Physical Memory : 1.70 GB
Available Memory: 1015.96 MB
***** CPU Information
Model Name: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
Processor  PhysicalID  CoreID  Frequency(MHz)
     0          0         0       3390.886
     1          1         0       3390.886
     2          2         0       3390.886
     3          3         0       3390.886
     4          4         0       3390.886
     5          5         0       3390.886
     6          6         0       3390.886
     7          7         0       3390.886
Machine Load: 0 out of 8 processor cores busy.
SIM_WARNING[HIN274]: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/SPECTREINCLUDE/quantity.spectre:6: The line with quantity is ignored..
SIM_WARNING[HIN274]: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/SPECTREINCLUDE/quantity.spectre:12: The line with quantity is ignored..
SIM_WARNING[HIN274]: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/SPECTREINCLUDE/quantity.spectre:18: The line with quantity is ignored..
SIM_WARNING[HIN274]: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/SPECTREINCLUDE/quantity.spectre:24: The line with quantity is ignored..
SIM_WARNING[HIN274]: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/SPECTREINCLUDE/quantity.spectre:30: The line with quantity is ignored..
        Further occurrences of this warning will be suppressed.
Circuit has only 28 unmerged elements; the AFS Nano license needed has already been acquired at invocation
SIM_WARNING[ANA307]: Multi-threading (MT) disabled; it is enabled by default only for transient analysis alone or if accompanied by dc/monte/alter/sweep/data analyses. To enforce multi-threading please specify --mt/-N command-line options.
Number of processor cores (limited by system) available: 8
Number of processor cores to be used for multi-threading a single simulation run (mt): 1
SIM_WARNING[GEN93]: No DC path to ground from node lna_inP on bsim3v31 'I2.M1', adding gmin= 1.000000e-12
SIM_WARNING[GEN93]: No DC path to ground from node lna_inN on bsim3v31 'I2.M0', adding gmin= 1.000000e-12
SIM_WARNING[GEN93]: No DC path to ground from node net22 on simple capacitor 'C8', adding gmin= 1.000000e-12
Summary of possible problems in circuit:
  Open-circuit current source   0
  Dangling MOS gate             0
  Dangling MOS bulk             0
  Dangling BJT substrate        0
  Dangling controlling node     0
  Dangling controlled isource   0
  Non-rail bulk terminal        0
Running a single threaded (--mt 1) simulation
Circuit equation has 16 nodes 24 unknowns 28 elements
Circuit has no internal nodes in MOS elements.
Circuit inventory:
                      bsim3v31   6
                     capacitor   7
                      inductor   2
                       isource   1
                          port   2
                      resistor   4
                   transformer   2
                       vsource   4
bin parameters        #resistors  #merged    #trimmed  #dangling
1.0e+01 -> 1.0e+02          2          0          0          0
1.0e+03 -> 1.0e+04          2          0          0          0
bin parameters        #capacitors  #merged    #trimmed  #dangling
1.0e-13 -> 1.0e-12          3          0          0          0
1.0e-11 -> 1.0e-10          4          0          0          0
bin parameters        #inductors  #merged    #trimmed  #dangling
1.0e-08 -> 1.0e-07          2          0          0          0
***** Options Used
reltol=0.0001 vabstol=1e-06 iabstol=1e-12 temp=27 tnom=27 scale=1.0 gmin=1e-12 rforce=1 maxwarns=5
save=all
post
temp=27
***** Options Ignored
scalem maxnotes digits cols pivrel sensfile "../psf/sens.output" checklimitdest psf
***** Analyses Used
dcOp dc maxiter = 150 maxsteps = 10000 annotate = status
SIM_WARNING[ANA199]: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/lna_dna_advisor.scs:92: Keyword annotate ignored.
dcOpInfo info what = oppoint where = rawfile largesignalname = dcOp
Trying to upgrade licensing by exchanging 1 AFS Nano license(s) with 1 AFS license(s) to enable 'pss' analysis
Released AFS Nano license
All AFS Nano licenses released for upgrading to AFS license(s).
Trying to acquire the initial AFS license
Acquired AFS license
Upgrade from AFS Nano license mode to AFS license mode successful
pss pss tperiod = 4.1666666666666668e-10 nharm = 7 errpreset = conservative tstab = 1e-08 annotate = status
SIM_WARNING[ANA199]: /home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/lna_dna_advisor.scs:119: Keyword annotate ignored.
designParamVals info what = parameters where = rawfile largesignalname = dcOp
***** Info analyses Ignored
modelParameter info what = models where = rawfile largesignalname = dcOp
element info what = inst where = rawfile largesignalname = dcOp
outputParameter info what = output where = rawfile largesignalname = dcOp
primitives info what = primitives where = rawfile largesignalname = dcOp
subckts info what = subckts where = rawfile largesignalname = dcOp
***** Parsing and Setup Complete; Total Parsing Time:
        Wallclock Time: 00 00:00:00
        CPU Time: 00 00:00:00
**** Probe Information
7 Simple probes.
Total number of probes 7
Starting Operating Point Analysis..
        reltol = 0.0001
        abstol(I) = 1 pA
        abstol(V) = 1 uV
        temp = 27 C
        tnom = 27 C
        gmin = 1 pS
        useabsorbedrds = no
        fixtopologyresistor = 1e+12
        merge = yes
        postprocessmeasure = no
        uselumpedmodel = 0
        mt = 1
        msolver = 0
        msolverdc = new auto selection
        maxiterationsfordc = 150
        ctrim = 0
        rtrim = 0
        seriesmerge = OFF
        remove dangling element = ON
        fixdanglingnodes = 2
Starting traditional Newton Raphson..
SIM_WARNING[ANA4]: For dc analysis, traditional Newton Raphson did not converge.
Starting allgmin stepping..
For dc analysis, allgmin stepping successful at 1.000000e-03
For dc analysis, allgmin stepping successful at 1.000000e-04
For dc analysis, allgmin stepping successful at 1.000000e-05
For dc analysis, allgmin stepping successful at 1.000000e-06
For dc analysis, allgmin stepping successful at 1.000000e-07
For dc analysis, allgmin stepping successful at 1.000000e-08
For dc analysis, allgmin stepping successful at 1.000000e-09
For dc analysis, allgmin stepping successful at 1.000000e-10
For dc analysis, allgmin stepping successful at 1.000000e-11
For dc analysis, allgmin stepping successful at 1.000000e-12
allgmin stepping finished successfully.
For DC analysis, allgmin stepping finished successfully.
***** Simulation Statistics For This Analysis:
Elapsed WallClock Time (HH:MM:SS) in Analysis: 00 00:00:00.
Elapsed WallClock Time (HH:MM:SS) in Analysis (excluding setup) : 00 00:00:00.
DC: Time in Analysis: 00 00:00:00.
Number of TimeSteps:          0.
Current Process  Resident Memory (KB): 38472
Operating Point Analysis finished successfully.
Starting Info Analysis..
Info Analysis finished successfully.
Starting Periodic Steady State Analysis..
        fund = 2.40 GHz
        npoints = 200
        tstart = 0 s
        tstab = 10 ns
        skipdc = no
        reltol = 1e-05
        abstol(I) = 1 pA
        abstol(V) = 1 uV
        temp = 27 C
        tnom = 27 C
***** For DC analysis, traditional Newton Raphson finished successfully.
Trying step 1 during PSS analysis..
Autoselected Solver 0
Running transient from 0.000000e+00 to 1.000000e-08.
....10....20....30....40....50....60....70....80....90....100
Tstab transient has 2.400e+01 cycles of fund = 2.400e+09 Hz, took elapsed time = 1.139e-01 and cpu time = 3.200e-02
Running transient from 1.000000e-08 to 1.041667e-08.
   delta(V6#branch)= +1.95835e-07  converge norm= 2.1e+03
   delta(net24)= +0.000364319  converge norm= 77
   delta(net24)= +5.41632e-05  converge norm= 11
   delta(net24)= -0.000364482  converge norm= 77
   delta(net24)= +0.000143431  converge norm= 30
   delta(net24)= -0.000146207  converge norm= 31
   delta(net24)= -0.000231284  converge norm= 49
   delta(net24)= +0.000361367  converge norm= 76
   delta(net24)= +0.000168221  converge norm= 36
   delta(net24)= +8.20194e-05  converge norm= 17
   delta(net24)= -0.00052237  converge norm= 1.1e+02
   delta(net22)= +0.000934523  converge norm= 2e+02
   delta(net22)= +0.000134688  converge norm= 29
   delta(net24)= -0.00070648  converge norm= 1.5e+02
   delta(net24)= +0.00018001  converge norm= 38
   delta(net24)= -0.000355518  converge norm= 75
   delta(net22)= +0.000534548  converge norm= 1.1e+02
   delta(net24)= -0.000742961  converge norm= 1.6e+02
   delta(net24)= +0.00028541  converge norm= 60
   delta(net22)= +0.000594933  converge norm= 1.3e+02
   delta(net24)= -0.000661804  converge norm= 1.4e+02
residue(V4#branch)= -1.73264e-14  converge norm= 0.0015
Number of TimeSteps:        202.
Current Process  Resident Memory (KB): 41108
Periodic Steady State Analysis finished successfully.
List of Suppressed  Messages ([message id]: count (last suppressed message):
    [HIN274]: 4 (/home/linux/eda/mentor/bda_root/examples/afs/RF/Spectre/lna/SPECTREINCLUDE/quantity.spectre:54: The line with quantity is ignored..)
******** SIMULATION finished with 0 error(s) and 16 warning(s) ********
***** Acquiring a License Time:  0 00:00:00
Job End Time:   Mon Sep 15 23:20:19 2014
Elapsed time:  0 00:00:02
Released AFS license
发表于 2015-4-18 18:36:11 | 显示全部楼层
 楼主| 发表于 2015-4-18 21:12:48 | 显示全部楼层
回复 4# designstart
不知道afs mega的feature名字,不过一般好像一般有nano就可以了
发表于 2015-4-26 15:42:50 | 显示全部楼层
请上传
 楼主| 发表于 2015-4-26 21:00:14 | 显示全部楼层
新版2014_Q4可以使用mentor的license了
发表于 2015-4-27 14:58:48 | 显示全部楼层
回复 7# toad
请上传!
谢谢
发表于 2015-5-27 02:32:01 | 显示全部楼层
請問何處可下載2014-Q2的AFS?
感謝分享
发表于 2015-5-27 10:05:19 | 显示全部楼层
GMT+8, 2024-4-27 08:58 , Processed in 0.042385 second(s), 6 queries , Gzip On, Redis On.
