在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 3096|回复: 6
[原创] encounte里report timing后报出的density指的是什么
发表于 2015-2-5 09:21:56 | 显示全部楼层 |阅读模式
 楼主| 发表于 2015-2-5 09:26:18 | 显示全部楼层
急求!
发表于 2015-2-13 14:23:59 | 显示全部楼层
Use the queryDensityInBox command to get the density for a specific area in the design.
It is recommended that you use the queryPlaceDensity command for reporting the standard cell utilization. The standard cell utilization reported by the queryPlaceDensity command is calculated as:
( stdcell_area + block_area ) / alloc_area
where,
        stdcell_area = area_of_standard_cells + area_of_physical_cells (filler, Endcap, welltaps, power shutoff (PSO) and Decaps cells)
        block_area = area of the placed and unplaced blocks
        alloc_area = total_area_of_sites - area_of_blocked_sites
Note: The area of placed and unplaced blocks is zero if blocks are marked as FIXED . The FIXED blocks are not included in the calculation. The queryPlaceDensity command lists the block area if blocks are included in the standard cell utilization calculation.
Note: The following commands calculate the standard cell utilization using the same equation as queryPlaceDensity :
    checkPlace and checkDesign -place
    placeDesign
    timeDesign and optDesign (Does not use cell padding in the calculation for standard cell utilization)
    summaryReport
    dbFPlanRegRowDensity
    queryDensityInBox
发表于 2015-2-13 20:26:52 | 显示全部楼层
解释很专业, 赞一个,
发表于 2015-2-28 12:23:19 | 显示全部楼层
回复 4# icfbicfb
    把DOC上的东西搬运一下而已。有些人不是懒么?哈哈哈
发表于 2019-11-6 10:25:28 | 显示全部楼层
求来源文档。这两天在看timeDesign,queryDensityInBox,queryPlaceDensity,报的density和utilization的区别,但是没有找到相关资料。哭死。。。
发表于 2022-6-29 16:05:15 | 显示全部楼层
我理解这俩是一个东西
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 13:46 , Processed in 0.025701 second(s), 8 queries , Gzip On, Redis On.
