在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2061|回复: 1
Notation for Tool installation under fedora 21, centos7 OS
发表于 2015-1-17 13:01:04 | 显示全部楼层 |阅读模式
Dear Friends,  I have installed some EDA tools under Fedora 21, and after I did all steps and invoked the tool, Soldiers refused to move, or license file cannot be started normally; finally I figured out that it's about network naming updated in Fedora OS. Same thing happened on CENTOS7.
This Error can be found by kicking:  lmhostid, which will not normally return the correct MAC address of you Machine, so we have to go back to old style of network configuration in OS.  just because we don't know how to change the Soldiers's mind.
Here we go...
(1) ##  change "eno1" or "em1" to "eth0" : by  add net.ifnames=0 biosdevname=0 in /etc/sysconfig/grub
$vim  /etc/sysconfig/grub
      GRUB_CMDLINE_LINUX=”rd.lvm.lv=vg0/swap  net.ifnames=0 biosdevname=0 rd.lvm.lv=vg0/usr rhgb quiet”
(2) ## activate config
$grub2-mkconfig -o /boot/grub2/grub.cfg
(3) ## rename to ifcfg-eth0 :
$mv   /etc/sysconfig/network-scripts/ifcfg-eno1   /etc/sysconfig/network-scripts/ifcfg-eth0
$vim /etc/sysconfig/network-scripts/ifcfg-eth0
     change item:  NAME=eth0
(4) ## reboot and check:
$ ifconfig
     ## should list "eth0 xxxx"
(5) ##check the "lmhostid"  command result again.
$lmhostid
     ## if return the right MAC address, then we succeeded, then try to wake up your Old Soldiers .
Hope this solution help you, thanks .
<<  If you know, you should share with others >>
发表于 2017-8-8 13:50:04 | 显示全部楼层
Very good, Thanks!
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 23:13 , Processed in 0.020027 second(s), 8 queries , Gzip On, Redis On.
