在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2446|回复: 1
[求助] 请教各位大牛一个在linux下启动ModelSim 10.2c的问题。
发表于 2015-1-12 21:13:28 | 显示全部楼层 |阅读模式
系统:CentOS 5.11 64位按照http://www.360doc.com/content/13/1106/22/9206388_327271560.shtml介绍的安装破解后,在命令行下输入vsim出现以下错误:
vsim
Error: Itcl initialization: Can't find a usable itcl.tcl in the following directories:
    /opt/ModelSim10.2c/modeltech/linux_x86_64/itcl3.4 /opt/ModelSim10.2c/modeltech/tcl/itcl3.4 /opt/ModelSim10.2c/modeltech/linux_x86_64/itcl3.4 /opt/ModelSim10.2c/modeltech/linux_x86_64/../lib/itcl3.4 /opt/ModelSim10.2c/modeltech/linux_x86_64/../library /opt/ModelSim10.2c/modeltech/linux_x86_64/../../library /opt/ModelSim10.2c/modeltech/linux_x86_64/../../itcl/library /opt/ModelSim10.2c/modeltech/linux_x86_64/../../../itcl/library
This probably means that Itcl/Tcl weren't installed properly.
If you know where the Itcl library directory was installed,
you can set the environment variable ITCL_LIBRARY to point
to the library directory.
请问该怎么解决才好?
发表于 2017-10-27 00:06:32 | 显示全部楼层
我也有这个问题,解决了吗?
GMT+8, 2024-4-25 12:28 , Processed in 0.027853 second(s), 8 queries , Gzip On, Redis On.
