在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 30954|回复: 45
[资料] ALLEGRO PI电容模型库
发表于 2015-1-9 13:09:14 | 显示全部楼层 |阅读模式
ALLEGRO PI电容模型库村田电容,增加了1948种支持产品  K: x' k' b) [; {
本数据库是在这个设计工具上能使用的村田产品的等效电路数据库,利用本数据库,可使基于Cadence allegro®的高频电路设计有效地进行。
1. Introduction2 K7 g. H& B0 U/ O" k3 j
This manual describes how to install Murata Components Library for Cadence Allegro® pcb PI option.9 N" B  Z* g3 q' A' c
And this library supports following software." C  c* F4 z7 q
Allegro® PCB PI option 610 Version PSD15.1 or later3 q1 g5 T$ \  F/ `; s$ ]4 v
" B! p9 O+ i/ e! w6 Y% h5 a9 {
安装示例:
Installing the Library
1. Unzip the download file and get “Murata” folder.% `5 S! Y* v* }! q  l( q( N* q- Z
2. Move “Murata” folder to the path you want to install., v+ b1 V+ O" f, @) j' g! G7 N; ]
If the previous version was already installed and new “Murata” folder will be moved to the same path, delete previous “Murata” folder in advance, and then move new “Murata” folder. In this case, following steps is not needed.' s& Z. Z' K$ c9 ?2 Z. Y6 |, e, ^
This manual describes assuming that “Murata” folder is moved under “D:/PI_LIB” folder.4 X, X% j2 X/ @4 z
3. Start Allegro® PCB PI option 610.2 z$ F7 j/ n( g  K% W1 ]' J
4. Select “Setup” -> “User Preferences…” in the main window, and User Preferences Editor starts.. k" S. {8 ?- p0 g8 j
5. Select “Config_paths” in “Categories” and click “devpath” - Value button.
6. Click “New (Insert)” button and specify the library folder (D:/PI_LIB/Murata) in “devpath Item” dialog box.
7. Select “Design_paths” in “Categories” and click “dclpath” – Value button. And specify the library folder (D:/PI_LIB/Murata) as dclpath in the same way.3 K7 g4 r! h( v; @7 R
8. Click “OK” button to return to the main window and select “Analyze” -> “Library…” to start Signal Analysis Library Browser.
9. Click “Add existing Library ->” button and select “Local Library”.  N" I" l$ i' l. w
10. Select “cap_murata.dml” file under the library folder and click “Open” button in the open file dialog box.
11. Click “OK” button in Signal Analysis Library Browser to return to the main window, this completes the installation of the library.
*The Allegro® is a registered trademark of Cadence Design Systems,Inc.
murata_library_cadencee.zip
1.05 MB, 下载次数: 391 , 下载积分: 资产 -2 信元, 下载支出 2 信元
ALLEGRO PI电容模型库
发表于 2015-1-13 09:36:45 | 显示全部楼层
回复 1# suxiaoli3000
多谢分享!
发表于 2015-1-30 23:43:39 | 显示全部楼层
感谢版主贡献的好资料
发表于 2015-3-5 09:45:05 | 显示全部楼层
新思路!
发表于 2015-4-26 09:59:04 | 显示全部楼层
不是自带有,这跟自带的电容库有什么区别呢?
发表于 2015-5-6 21:01:53 | 显示全部楼层
学些顶贴!!!!!!!!!
发表于 2015-7-3 14:35:51 | 显示全部楼层
多谢分享
发表于 2015-8-20 15:48:28 | 显示全部楼层
下来看看看,库文件不够啊
发表于 2015-9-1 19:31:51 | 显示全部楼层
正在做这方面的内容,谢谢楼主分享
发表于 2015-12-8 15:23:08 | 显示全部楼层
多谢分享
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-20 08:19 , Processed in 0.034248 second(s), 10 queries , Gzip On, Redis On.
