1、Job Title:SoC asic Engineer Department: Cellular Engineering
Job Description: modem:
3G: TD-SCDMA and WCDMA modem development
4G: TD-LTE modem development
SoC: next generation cellphone SoC full design cycle from spec.to massproduction.
Largest chip inside Marvell.
1) R&D L2/L3 of the above protocol stacks.
2)Integration and Testing with the UE system.
Qualification:
MS degree in microelectronics, or electrical engineering.
At least three years working experience.
Experience in real design projects (front-end or backend) is a strongplus.
Good team work spirit and communication skill. Eager to learn, work and grow ina challenging project.
2、Job Title: ASIC Implementation Engineer Location: Shanghai/Beijing Job Description: - Block, IP macro or SoC level implementation in 28nm or20nm TSMC/UMC process - UPF Synthesis with Synopsys DC or DCT/G flows - RTL2Gate and Gate2Gate formal check with LEC and/orformality tools. - Working with BE team to timing closure in Primetime-SIon multi-corners and multi-modes -
Ability tobuild or perfect the EDA-methodology-flow with perl, tcl or shell - Knowledge on DFT (mbist/scan)will be an added advantage
Qualifications: - BSEE degree or above - Strong understanding of synthesis flowusing DC/DCT/DCG - for a low power (UPF) and high speed- complex SoC - Hands on experience with formalverification tools such as LEC and/or formality - Must have the CTS conceptions in ICC atP&R stage
- Strong STA skills. Must have thorough knowledge on closing timing at unit andtop level - Experience in mbist and scan will be plus - Proficient in Perl, Tcl and Shellprogramming -Good team work spirit 3、Job Title: ASIC DFT design Engineer Location: Shanghai/Beijing Job Description: -Block, IPand SoC level DFT implementation (JTAG, Scan, Mbist and Analog/IP test etc.)and RTL integration; -Participatein test spec/plan definition; create the DFT design document and signoffDFT review checklists; -Testpatterns/vectors generation and verification; -Interfaceto backend team on physical design and timing closure; -Interfaceto test engineers on ATE and vectors bring-up and debugging; -Chip DFTquality sign-off -DFT STA,constraint generation, formal and timing closure
Qualifications: - DFT design and integration experience - Hands on DFT implementation experience (Bscan, Mbist, DC/AC Scan, analogIP test circuit integration, IDDQ test, ATPG and test pattern verification) - Expertise with DFT tools from Synopsy, Mentor, Syntest etc. - Strong logic design and verification background - Experience in Synthesis and STA will be plus - Proficient in Perl, tcl and shell programming - BSEE degree or above - Good team work spirit If you are interested in the position, please send your resume to the following email address: jiangrr@marvell.com Subject of your email should be: School_Name_Applied position_Information source
Eg.SJTU_Zhang Peng _Data Analyst_BBS |
