在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2155|回复: 1
[求助] modelsim无波形显示
发表于 2014-12-1 23:03:17 | 显示全部楼层 |阅读模式
写了一个16位乘法器,生成testbench文件,照着特权同学的书修改testbench如下,但是联合modelsim仿真发现无任何信号,为什么?点击run-all后也无反应。本人刚学FPGA,菜鸟一枚,求指教!多谢!
mux16 i1 (
// port map - connection between master ports and signals/registers
.ain(ain),
.bin(bin),
.clk(clk),
.done(done),
.rst_n(rst_n),
.start(start),
.yout(yout)
initial
begin
clk=0;
forever
#10 clk=~clk;
end
integer i,j;
integer wrong_timer;
integer txt_file;
initial begin
start=1'b0;  //
ain=16'd0;
bin=16'd0;
wrong_timer=0;
txt_file=$fopen("txt_file.txt");
rst_n=1'b0;
#1000;
rst_n=1'b1;
$fdisplay(txt_file,"testbench is running!\n");
for(i=0;i<16'hffff;i=i+1) begin
    for(j=0;j<16'hffff;j=j+1)begin
     mux_task(i,j);
     end
end
$fdisplay(txt_file,"%d wrong!\n",wrong_timer);
$fdisplay(txt_file,"testbench is over!");
$stop;
end
reg [31:0] mux_result;
task mux_task;
    input [15:0] mux_a;
    input [15:0] mux_b;
    begin
      ain=mux_a;
      bin=mux_b;
      @(posedge clk);
      #2 start=1;
      @(posedge done);
      @(posedge clk);
      #2 mux_result =yout;
      @(posedge clk);
      #2 start=0;
      @(posedge clk);
    end
endtask
always @(posedge done) begin
     @(posedge clk);
     @(posedge clk);
     $fdisplay (txt_file,"ain=%d,bin=%d,yout=%d\t",ain,bin,mux_result);
     if (ain*bin==yout) $fdisplay(txt_file,"right\n");
     else begin
       $fdisplay(txt_file,"wrong\n");
       worng_timer=wrong_timer+1;
      end
     @(posedge clk);
   end
endmodule
无任何信号???
无任何信号???
 楼主| 发表于 2014-12-2 17:57:48 | 显示全部楼层
QUARTUS与modelsim联合仿真,modelsim无波形显示
回复 1# 落落happy520
   求指导啊!
GMT+8, 2024-4-26 00:18 , Processed in 0.022690 second(s), 10 queries , Gzip On, Redis On.
