rt,小弟最近在用altera做一个FPGA的工程。需要用到两个串联的时钟复用器,如下图所示:
clk_out最后是给了altera自带双口ram的写时钟断。在做apr后的时序分析时,有警告:
Critical Warning: Timing requirements not met 仔细看了报告里的描述,应该是hold的时序违约。我用的是TimeQuest做的,sdc如下:
# Generated by : Version 9.1 Build 222 10/21/2009 SJ Full Version
# Project : spi_80
# Revision : spi_80
# Date : Thu Nov 20 10:16:34 CST 2014
# WARNING: Expected ENABLE_CLOCK_LATENCY to be set to 'ON', but it is set to 'OFF'
# In SDC, create_generated_clock auto-generates clock latency
# Create generated clocks based on PLLs
derive_pll_clocks -use_tan_name
# Original Clock Setting Name: WRB
create_clock -period 200 -name {WRB_SCL_i} {WRB_SCL_i}
# Original Clock Setting Name: SCK
create_clock -period 200 -name {SCK_i} {SCK_i}
# Original Clock Setting Name: rCLK_ram
create_clock -period 200 -name rCLK_ram [get_ports {gram_rck}]
create_clock -period 100 -name dotclk [get_ports {dotclk}]
# ** Clock Latency
# ** Clock Uncertainty
# ** Multicycles
# ** Cuts
# ** Input/Output Delays
# ** Tpd requirements
# ** Setup/Hold Relationships
# ** Tsu/Th requirements
# ** Tco/MinTco requirements
# Entity Specific Timing Assignments found in
# the Timing Analyzer Settings report panel
# The following clock group is added to try to
# match the behavior of:
# CUT_OFF_PATHS_BETWEEN_CLOCK_DOMAINS = ON
set_clock_groups -exclusive -group {SCK_i} -group {WRB_SCL_i} -group {rCLK_ram} -group {dotclk}
请问大神们如何能解决这个hold违约啊?貌似跟时钟周期没有关系啊。新手求指导!非常感谢! |
