在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: JoyShockley
[讨论] 关于Analog/Mixed-Signal Verification, Behavior Modeling的讨论
发表于 2015-1-23 17:12:53 | 显示全部楼层
楼主,看了您的帖子,大大的赞赞赞!!!
不过,没有看见参考文献[6],能不能贴出名字,非常有兴趣!谢谢
发表于 2015-1-23 22:06:45 | 显示全部楼层
当年做折叠内插adc时,想写个折叠放大器的verilog-a模型,结果写了半天都写不出来,真郁闷,后来只能拿三角函数去近似,无语
发表于 2015-3-17 15:59:27 | 显示全部楼层
多谢分享,还需要好好学习
发表于 2015-3-17 19:26:08 | 显示全部楼层
好多文档啊
发表于 2015-4-9 20:12:28 | 显示全部楼层
回复 10# JoyShockley
   您好,我也要做ADPLL建模,能否指点下,谢谢。方便的话可以联系我,我QQ878357778,谢谢您。
发表于 2015-4-15 16:46:50 | 显示全部楼层
学习了 mark一下
发表于 2015-5-20 06:31:13 | 显示全部楼层
thnx!
发表于 2015-5-20 09:37:32 | 显示全部楼层
这个“Analog/Mixed-Signal Verification, Behavior Modeling”是书名么?
发表于 2015-5-21 19:52:10 | 显示全部楼层
you mentioned Verilog-AMS , there is wreal datatype, which will call digital simulator, but why you find out there is so big difference of simulation speed between Verilog and Verilog-AMS.
发表于 2015-5-21 22:18:01 | 显示全部楼层
回复 29# dandeng
   Simulation speed does not just depend on the language, but as well as the implementation of behavior model. If only event driven behavior models are included in mixed-signal simulation, no conservative statement, model with verilog-ams could be very fast, be comparable to verilog. For example, if you just use wreal in verilog-ams to describe analog behavior, then no analog simulation engine is invoke, it is almost the same as pure digital simulation.
GMT+8, 2024-4-25 21:57 , Processed in 0.027716 second(s), 5 queries , Gzip On, Redis On.
