在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: mdxuan
MMSIM_14.10.138 License problems!!!
发表于 2014-10-19 12:49:55 | 显示全部楼层
发表于 2014-10-19 12:56:21 | 显示全部楼层
Cadence 2013 patch很像已經不能用在 Cadence 2014版本的EDA tools
neter 发表于 2014-10-12 14:13
   The 2013 patch works fine on every piece of 2014 Cadence! and my almost all Cadence tools run in Virtuoso environment are now version 141 except a few - all patched by the 2013 patch.
发表于 2014-10-20 11:06:48 | 显示全部楼层
感謝12樓網友的分享,但您有嘗試把2013 patch用在ASSURA616 and EXT141的版本上嗎?
发表于 2014-10-20 11:16:36 | 显示全部楼层
neter 发表于 2014-10-20 11:06
    "The 2013 patch works fine on every piece of 2014 Cadence! and my almost all Cadence tools run in Virtuoso environment are now version 141 except a few - all patched by the 2013 patch."——这个的意思就是包含了我有的所有Cadence工具——包括所有141版工具以及Assura41-616!
发表于 2014-10-20 11:32:08 | 显示全部楼层
how can i get MMSIM14 ?
Islam2014 发表于 2014-10-11 18:33
    You can download all Cadence software directly from Cadence official website, free!!!
http://bbs.eetop.cn/thread-457073-1-1.html
发表于 2014-10-30 19:40:47 | 显示全部楼层
MMSIM13用不起来!换个试试
发表于 2014-10-31 19:07:38 | 显示全部楼层
Just wonder why you ever need to start up license server?  Once you having applied the 2013 patch to every Cadence software, you never ever need to start up Cadence license server, at least that's the way I run all Cadence software in Virtuoso environment on Kubuntu/Ubuntu 14.04.
Does it mean there is not need CDS_LIC_FILE variable to be set at all, and there is not need any license file to be used?
发表于 2014-11-1 00:22:00 | 显示全部楼层
Does it mean there is not need CDS_LIC_FILE variable to be set at all, and there is not need any ...
Jsanchez12345 发表于 2014-10-31 19:07
    You do need to have the license.dat and the CDS_LIC_FILE set up correctly since virtuoso environment requires these to run.  See the shell script provided in my tutorial http://bbs.eetop.cn/thread-452284-1-1.html on how to set these up correctly.
发表于 2014-11-1 17:20:55 | 显示全部楼层
回复 14# min4max
Cadence IC616 DEFT?
http://bbs.eetop.cn/thread-451897-1-1.html
发表于 2014-11-3 14:52:48 | 显示全部楼层
Yes, that is known, but I asked because of that post:
I am interested particularly in PVS/PVE tool. The license file for IC610 is not compatible with PVS versions higher than v10 so I was wondering if this 2013 patch will modify PVS13 in that way that it will work without necessity of a license file.
GMT+8, 2024-3-29 13:21 , Processed in 0.027774 second(s), 6 queries , Gzip On, Redis On.
