查看: 19277|回复: 38
MMSIM_14.10.138 License problems!!!
发表于 2014-10-11 00:37:57 | 显示全部楼层 |阅读模式
On 09-Oct-2014 Cadence released MMSIM  14.10.138. I used the way that patched successful with MMSIM 13.11.252 .However, It failed with MMSIM 14.1. Any help? I were used this patch
:binary/5589E557565381ECD00000008B5508/31C0C357565381ECD00000008B5508/:binary/5589E557565381ECD8000000E8000000005B81C3/33C0C357565381ECD8000000E8000000005B81C3/:binary/41574989FF415641554154554889CD534489C3/33C0C389FF415641554154554889CD534489C3/
Patched
Patched
Failed to check license
发表于 2014-10-11 08:08:57 | 显示全部楼层
强烈要求lz上传MMSIM14
发表于 2014-10-11 15:27:01 | 显示全部楼层
回复 2# lhqin1986
    Version 14 maybe has changed the encrypt-algorithm!
发表于 2014-10-11 18:33:34 | 显示全部楼层
how can i get MMSIM14 ?
发表于 2014-10-12 01:58:46 | 显示全部楼层
I think it's a cdslmd issue.Have you ever tried to start-up your license server by using recently supplied cdslmd in MMSIM 14 package ?
It's working fine for me.I guess you're using old cdslmd and therefore it doesn't recognize recent codewords.Download newest License Utility and set-up a brand new license server using with recent cdslmd.Your patch is correct, no doubt.
发表于 2014-10-12 14:13:41 | 显示全部楼层
Cadence 2013 patch很像已經不能用在 Cadence 2014版本的EDA tools
发表于 2014-10-12 23:26:34 | 显示全部楼层
回复 5# T.Maxwell
Glorious Guru!
发表于 2014-10-18 22:19:30 | 显示全部楼层
Thanks for your sharing the information.
发表于 2014-10-19 12:40:59 | 显示全部楼层
    Well, both the license and the patch used for MMSIM131 work fine on MMSIM141, at least in my case on Kubuntu/Ubuntu 14.04!
Here're some simulation results by MMSIM141:
发表于 2014-10-19 12:47:14 | 显示全部楼层
I think it's a cdslmd issue.Have you ever tried to start-up your license server by using recently su ...
T.Maxwell 发表于 2014-10-12 01:58
    Just wonder why you ever need to start up license server?  Once you having applied the 2013 patch to every Cadence software, you never ever need to start up Cadence license server, at least that's the way I run all Cadence software in Virtuoso environment on Kubuntu/Ubuntu 14.04.
GMT+8, 2025-8-7 14:23 , Processed in 0.026026 second(s), 6 queries , Gzip On, Redis On.
