在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 5713|回复: 7
verdi和nlint无法启动,求各位大神帮忙。
发表于 2014-8-25 17:50:43 | 显示全部楼层 |阅读模式
RT~~~按照网上的破解一步一步来的。安装环境是Redhat Enterprise linux 6.5  i386
环境变量设置如下:
############novas verdi##########################
export VERDI_HOME="/usr/eda/novas/verdi201307"
export LM_LICENSE_FILE=28009@DELLLM_LICENSE_FILE
export PATH=$PATH:/usr/eda/novas/verdi201307/bin
alias lm="/usr/eda/novas/verdi201307/platform/LINUX64/bin/lmgrd -c /usr/eda/novas/vedi201307/license/license.dat"
###########novas nlint############################
export SNS_HOME=/usr/eda/novas/nlint201110/
export PATH=$PATH:/usr/eda/novas/nlint201110/bin
用的破解:http://bbs.eetop.cn/thread-428165-1-1.html
启迪snslmgrd提示如下: 20:41:33 (lmgrd) -----------------------------------------------
20:41:33 (lmgrd)   Please Note:
20:41:33 (lmgrd)
20:41:33 (lmgrd)   This log is intended for debug purposes only.
20:41:33 (lmgrd)   There are many details in licensing policies
20:41:33 (lmgrd)   that are not reported in the information logged
20:41:33 (lmgrd)   here, so if you use this log file for any kind
20:41:33 (lmgrd)   of usage reporting you will generally produce
20:41:33 (lmgrd)   incorrect results.
20:41:33 (lmgrd)
20:41:33 (lmgrd)
20:41:33 (lmgrd)
20:41:33 (lmgrd) lmgrd running as root:
20:41:33 (lmgrd)
This is a potential security problem
20:41:33 (lmgrd)
And is not recommended
[root@DELL 桌面]# 20:41:33 (lmgrd) FLEXlm (v9.23) started on DELL (linux) (8/27/2014)
20:41:33 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
20:41:33 (lmgrd) US Patents 5,390,297 and 5,671,412.
20:41:33 (lmgrd) World Wide Web:  http://www.macrovision.com
20:41:33 (lmgrd) License file(s): /usr/eda/novas/nlint201110/license/license.dat
20:41:33 (lmgrd) lmgrd tcp-port 28009
20:41:33 (lmgrd) Starting vendor daemons ...
20:41:33 (lmgrd) Started snslmgrd (internet tcp_port 57452 pid 4087)
20:41:33 (snslmgrd) FLEXnet Licensing version v11.6.0.0 build 60117 i86_re3
20:41:33 (snslmgrd) lmgrd version 9.2, snslmgrd version 11.6
20:41:33 (snslmgrd) Server started on DELL for:
nLint
20:41:33 (snslmgrd) nLint_either
nLint_mixed
nLint_sv
20:41:33 (snslmgrd) nLint_verilog
DataExpansionCoverage DataExpansionSim
20:41:33 (snslmgrd) DataReplay
Debussy
Debussy_shared
20:41:33 (snslmgrd) EssentialSignalAnalysis Extraction
FL_cosim_run
20:41:33 (snslmgrd) FL_ice_run
FL_multichip_partition FL_recalc
20:41:33 (snslmgrd) Gaia
Gate2layoutCorrelation Gate2RTLCorrelation
20:41:33 (snslmgrd) Gsim_dump_advance Gsim_dump_basic Gsim_framework_basic
20:41:33 (snslmgrd) Gsim_snapshot
Gsim_wave
GuidedTraceAnalysis
20:41:33 (snslmgrd) hdl2SC_mixed
HDL2SC_verilog
HDL2SC_vhdl
20:41:33 (snslmgrd) Laker_AMS
Laker_L1
Laker_L3
20:41:33 (snslmgrd) Laker_T1
Laker_T1_LE
Laker_Viewer
20:41:33 (snslmgrd) Laker_iDRC
Laker_iLVS
Reusner
20:41:33 (snslmgrd) RtlGateCorrelation SKDB_Import
Siloti
20:41:33 (snslmgrd) Siloti_fe
Siloti_o2
SimVE
20:41:33 (snslmgrd) TLM_Synthesis
TestDesignCorrelation TestVE
20:41:33 (snslmgrd) TimingAnalysis
Verdi
hdlin
20:41:33 (snslmgrd) hdlin_mixed
hdlin_verilog
hdlin_vhdl
20:41:33 (snslmgrd) nAnalyzer
nClock
nCompare
20:41:33 (snslmgrd) nECO
nESL
nMonitor
20:41:33 (snslmgrd) nProp
nSchemaOnly
nState
20:41:33 (snslmgrd) nTiming
nTrace
nTree
20:41:33 (snslmgrd) nlcc
tSchema
turboSchema
20:41:33 (snslmgrd) turboState
turboTracer
turboWave
20:41:33 (snslmgrd) EXTERNAL FILTERS are OFF
20:41:33 (lmgrd) snslmgrd using TCP-port 57452
我觉得这license 应该是启动了
但是 运行verdi和nlint报错:
All Rights Reserved.
www.synopsys.com
This computer program constitutes or contains trade secrets and confidential
information of Synopsys, Inc. or its licensors. This computer program is
protected by copyright law and international treaties.
rcfile = /usr/eda/novas/novas201010/etc/novas.rc
guiConfFile = /root/桌面/novas.conf
Could not checkout Verdi license. Use Verdi -licdebug for more information.
[1]+  Done                    verdi
运行nlint报错:logDir = /root/桌面/nLintLog
rcfile = /usr/eda/novas/nlint201110/etc/nLint.rc
nLint - A HDL Design Rule Checker, Release 2011.10 (Linux x86_64/64bit) 09/20/2011
Copyright (C) 1996 - 2011 by SpringSoft, Inc.
*WARN* Failed to check out license.
顾名思义就是 license 问题,我前面启动license服务的时候 没有发现明显错误。
求大神帮忙········
 楼主| 发表于 2014-8-26 09:52:16 | 显示全部楼层
自己顶
发表于 2014-9-3 00:00:11 | 显示全部楼层
我也是这个问题,帮顶
发表于 2014-11-24 15:01:04 | 显示全部楼层
帮顶,我也是这个问题。楼主后来解决了么?
发表于 2015-7-9 09:23:16 | 显示全部楼层
我也有同样的问题
发表于 2015-7-31 18:58:52 | 显示全部楼层
顶一下!
发表于 2015-12-4 23:24:25 | 显示全部楼层
发表于 2015-12-7 19:55:34 | 显示全部楼层
怎么解决的,有搞定的吗!
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 07:01 , Processed in 0.041724 second(s), 8 queries , Gzip On, Redis On.
