在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: 真我个性
RHEL6.x86_64位系统Cadence ic616和Mmsim13安装教程
发表于 2014-12-1 15:08:39 | 显示全部楼层
why old cadence tools IC5141?
I just have it, and want to know if I move to Centos6 (now I am using Centos 5) it will remain working.
发表于 2014-12-1 19:38:29 | 显示全部楼层
好东西!
发表于 2014-12-1 21:30:30 | 显示全部楼层
照做了,为什么最后会出现*ERROR* (DB-320001): Unable to get the Cadence(R) Design Framework II license feature "111".
lmgrd
[root@JIMMY jimmy]# lmgrd
5:30:14 (lmgrd) -----------------------------------------------
5:30:14 (lmgrd)   Please Note:
5:30:14 (lmgrd)
5:30:14 (lmgrd)   This log is intended for debug purposes only.
5:30:14 (lmgrd)   In order to capture accurate license
5:30:14 (lmgrd)   usage data into an organized repository,
5:30:14 (lmgrd)   please enable report logging. Use Flexera Software, Inc.'s
5:30:14 (lmgrd)   software license administration  solution,
5:30:14 (lmgrd)   FLEXnet Manager, to  readily gain visibility
5:30:14 (lmgrd)   into license usage data and to create
5:30:14 (lmgrd)   insightful reports on critical information like
5:30:14 (lmgrd)   license availability and usage. FLEXnet Manager
5:30:14 (lmgrd)   can be fully automated to run these reports on
5:30:14 (lmgrd)   schedule and can be used to track license
5:30:14 (lmgrd)   servers and usage across a heterogeneous
5:30:14 (lmgrd)   network of servers including Windows NT, Linux
5:30:14 (lmgrd)   and UNIX. Contact Flexera Software, Inc. at
5:30:14 (lmgrd)   www.flexerasoftware.com for more details on how to
5:30:14 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
5:30:14 (lmgrd)   for your enterprise.
5:30:14 (lmgrd)
5:30:14 (lmgrd)
5:30:14 (lmgrd)
5:30:14 (lmgrd) The license server manager (lmgrd) running as root:
5:30:14 (lmgrd)         This is a potential security problem
5:30:14 (lmgrd)         and is not recommended.
[root@JIMMY jimmy]#  5:30:14 (lmgrd) license manager: can't initialize:Cannot find license file.
5:30:14 (lmgrd) The license files (or license server system network addresses) attempted are
5:30:14 (lmgrd) listed below.  Use LM_LICENSE_FILE to use a different license file,
5:30:14 (lmgrd) or contact your software provider for a license file.
5:30:14 (lmgrd) Filename: "/home/jimmy/opt/cadence/share/license/license.dat"
5:30:14 (lmgrd) License Path: "/home/jimmy/opt/cadence/share/license/license.dat"
5:30:14 (lmgrd) FLEXnet Licensing error:-1,359
5:30:14 (lmgrd) System Error:2 No such file or directory
5:30:14 (lmgrd) For further information, refer to the FLEXnet Licensing documentation,available at "www.flexerasoftware.com".
5:30:14 (lmgrd) Using license file "/home/jimmy/opt/cadence/share/license/license.dat"
求救。。。我license.dat确实是放到了.../share/license/里面的啊。。为什么他说找不到呢。。
 楼主| 发表于 2014-12-2 09:00:05 | 显示全部楼层
回复 23# jimmyein
   license的第一行有没有修改?
发表于 2014-12-9 10:41:43 | 显示全部楼层
上传一个IC616的license吧?
发表于 2014-12-9 15:49:59 | 显示全部楼层
还有一个问题 你提供的链接里面 mmsim13的patch里面没用flexm文件。。。
 楼主| 发表于 2014-12-10 09:07:14 | 显示全部楼层
回复 25# 杜王町
   用PATCH就不需要license,patch是强行破解的
发表于 2014-12-15 14:29:41 | 显示全部楼层
zan zan!
发表于 2014-12-23 18:04:40 | 显示全部楼层
正在自己摸索安装 谢谢分享
发表于 2014-12-30 14:30:59 | 显示全部楼层
thx a lot
GMT+8, 2024-4-27 02:42 , Processed in 0.026588 second(s), 5 queries , Gzip On, Redis On.
