楼主: mabas.masood
calibre 2014
 楼主| 发表于 2014-7-26 02:41:52 | 显示全部楼层
回复 40# Islam2014
like calibre 2011
发表于 2014-7-26 03:52:41 | 显示全部楼层
回复 41# mabas.masood
   i installed it when i type in terminal calibre -gui
i got that error
ERROR: Current execution environment is VCO=aoi. Software tree is for environment VCO=ixl
 楼主| 发表于 2014-7-26 06:17:35 | 显示全部楼层
回复 42# chris2013
you must install centos 5
but you can change aoi with ixl in calibre bash code in
"<mentor install>/pkgs/icv/bin/calibre"
发表于 2014-7-26 07:45:22 | 显示全部楼层
回复 43# mabas.masood
it works thank you i replaced aoi with ixl in the 2 files in  /Calibre_Install_Dir/ixl_cal_2014.1_17.12/pkgs/calibre_base/bin
"calibre_env ,calibre_vco"
attached 2 files after edit
my OS Centos 6.5 X64 bit
calibre.rar (5.09 KB , 下载次数: 530 )
发表于 2014-8-5 14:45:08 | 显示全部楼层
xie xie !!!
发表于 2014-8-7 00:36:56 | 显示全部楼层
感謝大大分享
发表于 2014-8-15 19:26:09 | 显示全部楼层
回复 42# chris2013
   setenv CALIBRE_2013_4_ALLOW_IXL_ON_RHEL6 101010
发表于 2014-8-16 00:25:45 | 显示全部楼层
回复 47# snk88
   i'm using  Centos 6.5
发表于 2014-8-16 09:12:42 | 显示全部楼层
回复 48# chris2013
    亦可
发表于 2014-8-31 13:15:01 | 显示全部楼层
收了,非常感谢
GMT+8, 2025-11-7 05:18 , Processed in 0.020416 second(s), 4 queries , Gzip On, Redis On.
