在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 3683|回复: 9
[招聘] 西安找工作的同学注意了哦,待遇优厚的工作来了
发表于 2014-7-16 22:24:15 | 显示全部楼层 |阅读模式
我司目前因为项目进度,继续做andriod的工程师若干,需求如下:Android SW Integration profile with experiences on BT technology
  • ideally having performed SW integration work with 3rd parties vendor such as BCM (Broadcom)
Master in Computer Science, Computer Engineering or Electrical Engineering.
Minimum 7-8 years of experience in Linux embedded in the area of wireless platforms (smartphones/tablets)
Minimum 2 years specifically on BT integration/debug on Android platforms
Having worked previously on BCM components integration (BCM543x family) is a big PLUS
Very good knowledge of Embedded Linux environment and Android OS is mandatory
Experiencein other connectivity domains is a plus (Wi-Fi, NFC,…)
Very good knowledge of C/C++ and JAVA languages
Experience in using Version Control tools (GIT) for SW patches
Provide clear communication on personal work status
Be able to work in a multi-cultural multi-site environment and to interact easily with peers
Good level in English is mandatory, ideally both written and oral communication
Main activities:
Debug complex system issues across the SW stack including other platform components <- Methodology!
&#8226;
Provide expert level support and technical guidance to complex problem analysis and resolution (root cause) <- Methodology!
&#8226;
Interact with peers through Bugzilla web interface (or MS Lync or MS Outlook) to ask the bug submitter for information about the issue if needed
&#8226;
Two types of debug situations:
&#8226;
Trace/Logs are not provided -> Be able to reproduce the issue and to find out why the problem happens
&#8226;
Trace/Logs are provided        -> Be able to understand from the logs why the problem happens (root cause) especially if HW platform is not available in the Back-office
&#8226;
Submit SW patches on GIT (gerrit) review server for peer to review when applicable
&#8226;
Report integration/debug progress to management
  • 2) Android SW Integration profile with experiences on GNSS technology
&#8226;
&#8226;
&#8226;
Minimum 2 years specifically on GNSS integration/debug on Android platforms
&#8226;
&#8226;
&#8226;
Familiar with the different GNSS systems (GPS, Glonass, Beidoo/Compass, Galileo)
&#8226;
Familiar with aGPS (Control Plane (CP) and User Plane protocols (SUPLv1.0 and 2.0)
&#8226;
Experiencein other connectivity domains (Wi-Fi, BT, NFC…) or Modem Integration is a plus
&#8226;
&#8226;
&#8226;
&#8226;
&#8226;
&#8226;
Main activities:
&#8226;
&#8226;
&#8226;
&#8226;
&#8226;
&#8226;
&#8226;
&#8226;
一旦录用,待遇优厚哦,有意向的同学,可将简历发往jib20110930@126.com
发表于 2014-7-17 12:26:53 | 显示全部楼层
了解一下!!
 楼主| 发表于 2014-7-17 21:54:52 | 显示全部楼层
回复 2# ee_designer
如果觉得可以的话,可以发送简历到我的邮箱哦
 楼主| 发表于 2014-7-20 18:23:25 | 显示全部楼层
顶一下!
 楼主| 发表于 2014-7-21 20:36:45 | 显示全部楼层
再顶一下
 楼主| 发表于 2014-7-25 21:36:04 | 显示全部楼层
再顶一下
发表于 2014-8-6 13:33:35 | 显示全部楼层
顶一下!
发表于 2014-8-6 13:34:57 | 显示全部楼层
顶一下!
 楼主| 发表于 2014-8-8 22:44:24 | 显示全部楼层
回复 8# gujie0216
谢谢,再顶一下
 楼主| 发表于 2014-8-10 19:19:19 | 显示全部楼层
再顶一下
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-25 03:39 , Processed in 0.042651 second(s), 9 queries , Gzip On, Redis On.
